Home » Archived » BIRT » Cannot run report properly while using aggregations
Re: Cannot run report properly while using aggregations [message #898619 is a reply to message #898102] |
Thu, 26 July 2012 21:56 |
Robert,
A couple of things. Unless you are using the 4.2 OSGi runtime do not
set the EngineHome. If you are just adding the runtime jars to the
classpath (POJO runtime) this call will cause issues. Also only startup
the platform once for the lifetime of you app. In webapps generally you
create the engine in a singleton. In a command line app just start it
up when you start and shut it down when you are finished. Can you try
running the code below with the attached rptdesign?
package REAPI;
import java.util.Locale;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EXCELRenderOption;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IRenderOption;
import org.eclipse.birt.report.engine.api.IRenderTask;
import org.eclipse.birt.report.engine.api.IReportDocument;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunTask;
import org.eclipse.birt.report.engine.api.RenderOption;
public class RunThenRenderTaskXls {
public void runReport() throws EngineException
IReportEngine engine=null;
EngineConfig config = null;
IReportDocument document = null;
try{
config = new EngineConfig( );
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
..createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
IReportRunnable design = null;
design = engine.openReportDesign("Reports/average.rptdesign");
IRunTask task = engine.createRunTask(design);
task.setLocale(new Locale("en", "US"));
task.run("output/resample/average.rptdocument");
task.close();
document =
engine.openReportDocument("output/resample/average.rptdocument");
EXCELRenderOption options = new EXCELRenderOption();
options.setOutputFormat("xls");
options.setOutputFileName("output/resample/average.xls");
options.setOption(IRenderOption.HTML_PAGINATION, true);
IRenderTask rtask = engine.createRenderTask(document);
rtask.setLocale(new Locale("en", "US"));
rtask.setRenderOption(options);
rtask.render();
rtask.close();
document.close();
engine.destroy();
System.out.println("Finished");
}catch( Exception ex){
ex.printStackTrace();
finally
Platform.shutdown( );
* @param args
try
RunThenRenderTaskXls ex = new RunThenRenderTaskXls( );
ex.runReport();
catch ( Exception e )
e.printStackTrace();
Jason
On 7/25/2012 3:28 PM, Robert LaDue wrote:
> I am trying to use BIRT to take sample inputs of date and numbers and
> output them to an .xls file along with the average of the numbers.
> I have built an .rptdesign file consisting solely of a table containing
> the following information: A header row with text ("date" + "number"). A
> detail row with the data (the date and number data). A footer row
> containing text ("Average"), and an aggregation with the function AVE,
> and the expression row["Number"].
> I have written a java program to run and render the .rptdesign into an
> .rptdocument file, and subsequently into an .xls file. The issue lies in
> the fact that whenever the aggregation is present, none of the data is
> placed into the .rptdocument file when my code is run. The output is
> only the text fields. The data and aggregation simply disappear.
> Manually generating an .rptdocument through the 'run' menu in eclipse
> works perfectly, and the render turns out fine. This has led me to
> believe there is something wrong with my code, but I am at a loss for
> what it could be.
> Here is the code in question:
> package code;
> import org.eclipse.birt.report.engine.api.*;
> import org.eclipse.birt.core.exception.BirtException;
> import java.util.logging.Level;
> public class RenderDoc {
> public static void main( String[] args ){
> try {
> runStuff ();
> renderStuff ();
> } catch (EngineException e) {
> // TODO Auto-generated catch block
> } catch (BirtException e) {
> } catch (Exception e) {
> //Runs report from .rptdesign to .rptdocument
> public static void runStuff () throws BirtException{
> EngineConfig config = new EngineConfig();
> Config(config);
> //TODO why does this error now?
> Platform.startup(config);
> IReportEngine engine = factory.createReportEngine(config);
> engine.changeLogLevel( Level.WARNING );
> engine.openReportDesign("C:\\Users\\Rob\\workspace\\renderDocument\\stock.rptdesign");
> //Create task to run the report - use the task to execute the
> report and save to disk.
> //run the report and destroy the engine
> task.run("C:\\Users\\Rob\\workspace\\renderDocument\\outputTest.rptdocument");
> task.close();
> engine.destroy();
> //Renders report from .rptdocument to .xls
> public static void renderStuff () throws BirtException{
> Config(config);
> //ReportEngine engine = new ReportEngine(null);
> document =
> engine.openReportDocument("C:\\Users\\Rob\\workspace\\renderDocument\\outputTest.rptdocument");
> options.setOutputFileName("C:\\Users\\Rob\\workspace\\renderDocument\\stockInfo.xls");
> org.eclipse.birt.report.engine.api.IRenderTask task =
> engine.createRenderTask(document); task.setRenderOption(options);
> task.render();
> engine.destroy();
> Platform.shutdown();
> protected static void Config(EngineConfig C)
> C.setEngineHome ("C:\\BIRT\\birt-runtime-4_2_0\\ReportEngine");
> C.setLogConfig("C:\\temp", Level.FINE);
> return;
Attachment: average.zip
(Size: 2.44KB, Downloaded 141 times)
Re: Cannot run report properly while using aggregations [message #898620 is a reply to message #898102] |
Robert,
package REAPI;
try{
task.close();
document =
rtask.render();
rtask.close();
document.close();
engine.destroy();
finally
* @param args
try
ex.runReport();
Jason
> what it could be.
> package code;
> try {
> runStuff ();
> renderStuff ();
> Config(config);
> task.close();
> engine.destroy();
> Config(config);
> document =
> task.render();
> engine.destroy();
> return;
(Size: 2.44KB, Downloaded 154 times)
Re: Cannot run report properly while using aggregations [message #898621 is a reply to message #898102] |
Robert,
package REAPI;
try{
task.close();
document =
rtask.render();
rtask.close();
document.close();
engine.destroy();
finally
* @param args
try
ex.runReport();
Jason
> what it could be.
> package code;
> try {
> runStuff ();
> renderStuff ();
> Config(config);
> task.close();
> engine.destroy();
> Config(config);
> document =
> task.render();
> engine.destroy();
> return;
(Size: 2.44KB, Downloaded 142 times)
Re: Cannot run report properly while using aggregations [message #898623 is a reply to message #898102] |
Robert,
package REAPI;
try{
task.close();
document =
rtask.render();
rtask.close();
document.close();
engine.destroy();
finally
* @param args
try
ex.runReport();
Jason
> what it could be.
> package code;
> try {
> runStuff ();
> renderStuff ();
> Config(config);
> task.close();
> engine.destroy();
> Config(config);
> document =
> task.render();
> engine.destroy();
> return;
(Size: 2.44KB, Downloaded 144 times)
Re: Cannot run report properly while using aggregations [message #898624 is a reply to message #898102] |
Robert,
package REAPI;
try{
task.close();
document =
rtask.render();
rtask.close();
document.close();
engine.destroy();
finally
* @param args
try
ex.runReport();
Jason
> what it could be.
> package code;
> try {
> runStuff ();
> renderStuff ();
> Config(config);
> task.close();
> engine.destroy();
> Config(config);
> document =
> task.render();
> engine.destroy();
> return;
(Size: 2.44KB, Downloaded 198 times)
Re: Cannot run report properly while using aggregations [message #898625 is a reply to message #898102] |
Robert,
package REAPI;
try{
task.close();
document =
rtask.render();
rtask.close();
document.close();
engine.destroy();
finally
* @param args
try
ex.runReport();
Jason
> what it could be.
> package code;
> try {
> runStuff ();
> renderStuff ();
> Config(config);
> task.close();
> engine.destroy();
> Config(config);
> document =
> task.render();
> engine.destroy();
> return;
(Size: 2.44KB, Downloaded 145 times)
Current Time: Thu Apr 25 10:59:59 GMT 2024
Powered by FUDForum. Page generated in 0.04119 seconds
