Re: Does birt support nested axis label [message #898614 is a reply to message #898061] |
Thu, 26 July 2012 21:32 |
Not natively but you can do similar things with script. Look at the
attached two examples. Specifically the adjustaxis example. If you
look at the x-value expression data is put in that is trimmed in script
and a new line is added.
Jason
On 7/25/2012 1:28 PM, DONG YAO wrote:
> like this
> |JAN|FEB|MAR|APR|MAY|JUN|
> | Q1 | Q2 |
Re: Does birt support nested axis label [message #899615 is a reply to message #899451] |
Wed, 01 August 2012 15:01 |
Currently BIRT does not have nested labeling. In the example I posted
on space control you can know using the afterDataSet event how many data
points you will have. This will make the script a bit complex so I know
it is not ideal. The only other option I can think of is to implement a
chart type extension that provides this functionality. Can you log a
bugzilla request for this enhancement?
Jason
On 7/31/2012 5:38 PM, DONG YAO wrote:
> Also, the first line in x label, we need display the text vertically
> (degree 90). I tried that on the second example, no label was shown on x
> axis.
FUDForum. Page generated in 0.03335 seconds
