Home » Modeling » TMF (Xtext) » Updating Xtext 2.2.1 to 2.3.0
Updating Xtext 2.2.1 to 2.3.0 [message #897930] Wed, 25 July 2012 13:06 Go to next message
Aaron Digulla is currently offline Aaron DigullaFriend
I couldn't find any documents about upgrading from 2.2.1 to 2.3.0. The release notes only mention new features.
1. Are there any code changes necessary to update to 2.3.0?
2. Should it be possible to update Eclipse using the archived update site from http://www.eclipse.org/modeling/tmf/downloads/?
A. Digulla
Re: Updating Xtext 2.2.1 to 2.3.0 [message #897940 is a reply to message #897930] Wed, 25 July 2012 13:27 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
> http://www.eclipse.org/Xtext/releasenotes/2.3.0/new_and_noteworthy.php
Depends on your customizations. I have quite a few complicated
customizations, and managed to move my code from 2.2.1 to 2.3.0 in 1-2
hours.
- henrik
Re: Updating Xtext 2.2.1 to 2.3.0 [message #898369 is a reply to message #897940] Thu, 26 July 2012 09:34 Go to previous messageGo to next message
How about updating the Eclipse plug-ins? Did anyone manage that? Is/should it be possible?
I get lots of errors from p2 because many Xtext bundles are singletons and Eclipse refuses to update them :-/ Two examples are the docs and examples:
Xtext documentation
Cannot complete the install because of a conflicting dependency.
  Software being installed: Xtext Documentation 2.3.0.v201206120633 (org.eclipse.xtext.docs.feature.group 2.3.0.v201206120633)
  Software currently installed: Xtext SDK 2.2.1.v201112130541 (org.eclipse.xtext.sdk.feature.group 2.2.1.v201112130541)
  Only one of the following can be installed at once:
    Xtext Documentation 2.3.0.v201206120633 (org.eclipse.xtext.doc 2.3.0.v201206120633)
    Xtext Documentation 2.2.1.v201112130541 (org.eclipse.xtext.doc 2.2.1.v201112130541)
  Cannot satisfy dependency:
    From: Xtext Documentation 2.3.0.v201206120633 (org.eclipse.xtext.docs.feature.group 2.3.0.v201206120633)
    To: org.eclipse.xtext.doc [2.3.0.v201206120633]
    From: Xtext SDK 2.2.1.v201112130541 (org.eclipse.xtext.sdk.feature.group 2.2.1.v201112130541)
    To: org.eclipse.xtext.xtext.ui.feature.group [2.2.1.v201112130541]
    From: Xtext Xtext UI 2.2.1.v201112130541 (org.eclipse.xtext.xtext.ui.feature.group 2.2.1.v201112130541)
    To: org.eclipse.xtext.doc [2.2.1.v201112130541]
Xtext examples:
  Software being installed: Xtext Examples 2.3.0.v201206120633 (org.eclipse.xtext.examples.feature.group 2.3.0.v201206120633)
  Software currently installed: Xtext Xtext UI 2.2.1.v201112130541 (org.eclipse.xtext.xtext.ui.feature.group 2.2.1.v201112130541)
    Xtext Ecore Ui Support 2.3.0.v201206120633 (org.eclipse.xtext.ui.codetemplates 2.3.0.v201206120633)
    Xtext Ecore Ui Support 2.2.1.v201112130541 (org.eclipse.xtext.ui.codetemplates 2.2.1.v201112130541)
    From: Xtext Examples 2.3.0.v201206120633 (org.eclipse.xtext.examples.feature.group 2.3.0.v201206120633)
    To: org.eclipse.xtext.ui.feature.group [2.3.0,2.4.0)
    From: Xtext UI 2.2.1.v201112130541 (org.eclipse.xtext.ui.feature.group 2.2.1.v201112130541)
    To: org.eclipse.xtext.ui.codetemplates [2.2.1.v201112130541]
    From: Xtext UI 2.3.0.v201206120633 (org.eclipse.xtext.ui.feature.group 2.3.0.v201206120633)
    To: org.eclipse.xtext.ui.codetemplates [2.3.0.v201206120633]
    To: org.eclipse.xtext.ui.feature.group [2.2.1,2.3.0)
Xtext base:
  Software being installed: Xbase 2.3.0.v201206120633 (org.eclipse.xtext.xbase.feature.group 2.3.0.v201206120633)
  Software currently installed: Xtext UI 2.2.1.v201112130541 (org.eclipse.xtext.ui.feature.group 2.2.1.v201112130541)
    Xtext UI Core 2.3.0.v201206120633 (org.eclipse.xtext.ui 2.3.0.v201206120633)
    Xtext UI Core 2.2.1.v201112130541 (org.eclipse.xtext.ui 2.2.1.v201112130541)
    To: org.eclipse.xtext.ui [2.2.1.v201112130541]
    From: Xbase 2.3.0.v201206120633 (org.eclipse.xtext.xbase.feature.group 2.3.0.v201206120633)
    To: org.eclipse.xtext.xbase.ui [2.3.0.v201206120633]
    From: Xbase UI 2.3.0.v201206120633 (org.eclipse.xtext.xbase.ui 2.3.0.v201206120633)
    To: bundle org.eclipse.xtext.ui [2.3.0,3.0.0)
Why can't I install two versions of the docs?
A. Digulla
[Updated on: Thu, 26 July 2012 09:39]
Report message to a moderator
Re: Updating Xtext 2.2.1 to 2.3.0 [message #898443 is a reply to message #898369] Thu, 26 July 2012 11:46 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Am 26.07.12 11:34, schrieb Aaron Digulla:
Sure. "Check for updates" should do the trick.
That indicates an inconsistent manual selection of to-be-installed features.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Re: Updating Xtext 2.2.1 to 2.3.0 [message #898468 is a reply to message #898443] Thu, 26 July 2012 12:36 Go to previous messageGo to next message
In my experience, p2 is not perfect and I have had trouble when using
N-builds. It appears that
p2 does not always recognize that there is something consistently better
enabling it to kick out the
old. I have sometimes had to manually uninstall the unwanted version to
enable installation of the
new. This then works; I don't now why because often the uninstall breaks
the prerequisites of
other still installed software.
Anyway; just Uninstall problematic old stuff and you could be ok.
Ed Willink
> features.
Re: Updating Xtext 2.2.1 to 2.3.0 [message #898487 is a reply to message #898443] Thu, 26 July 2012 13:20 Go to previous messageGo to next message
Sebastian Zarnekow wrote on Thu, 26 July 2012 13:46
Damn.
In my case, it means that I must not merge your p2 update site with other update sites into one big update site Sad
I probably could use a composite p2 repo but that causes a lot of unnecessary traffic. *sigh*
What I don't understand: How can p2 update the bundles from your site (even though they are singletons) but not from mine?? Is there some trick to tell p2 that it can update a singleton?
A. Digulla
Re: Updating Xtext 2.2.1 to 2.3.0 [message #898498 is a reply to message #898487] Thu, 26 July 2012 13:38 Go to previous messageGo to next message
Have you checked that your non-updateable "singleton" is not bound by
something else that you are not updating ?
- henrik
Re: Updating Xtext 2.2.1 to 2.3.0 [message #898504 is a reply to message #898498] Thu, 26 July 2012 13:48 Go to previous messageGo to next message
Well, the error message says:
so basically, I can't update Xtext Documentation because Xtext SDK wants the old version of the docs.
But I get a similar error when I try to update Xtext SDK :-/ I just tried to come up with a shorter error message. I guess I'll have to try again.
[Updated on: Thu, 26 July 2012 13:53]
Re: Updating Xtext 2.2.1 to 2.3.0 [message #899015 is a reply to message #898487] Mon, 30 July 2012 07:43 Go to previous message
If you repackage Xtext features on an own update site, you have to make
sure that you include all features. Otherwise the update procedure won't
work since not all features that were previously installed can be
updated if you miss one of those.
Sebastian
Am 26.07.12 15:20, schrieb Aaron Digulla:
> Damn.
>> features.
> other update sites into one big update site :(
> Regards,
> A. Digulla
Previous Topic:JUnit test not using current validator
Next Topic:handling both latin-1 and utf-8 files
Current Time: Fri Sep 25 17:11:08 GMT 2020
Powered by FUDForum. Page generated in 0.02344 seconds
