NoClassDefFound on programmatic launch of the families2persons example [message #897763] |
Wed, 25 July 2012 08:37 |
Stefan L Messages: 13 Registered: July 2012 |
I'm getting a NoClassDefFoundError when running the famlies2persons example from http://www.eclipse.org/forums/index.php/m/632793/. I just use exactly the same source code and got my paths right. There is no problem when I run the transformation via the atl run configuration manually!
As im rather new to atl i would be pleased if someone could help me on this issue. The error at occurs at amh.createModelLoader();:
//AtlModelHandler and ModelLoader init
AtlModelHandler.registerDefaultHandler("EMF", new AtlEMFModelHandler());
AtlModelHandler amh = AtlModelHandler.getDefault("EMF");
ModelLoader ml = amh.createModelLoader();
I'm using the atl 3.3 jars as user library in my java application project.
Error message in detail:
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/core/runtime/Platform
at org.eclipse.m2m.atl.drivers.emf4atl.EMFModelLoader.<clinit>(EMFModelLoader.java:61)
at org.eclipse.m2m.atl.drivers.emf4atl.AtlEMFModelHandler.createModelLoader(AtlEMFModelHandler.java:43)
at Families2Persons.main(Families2Persons.java:21)
Stefan
[Updated on: Wed, 25 July 2012 09:43] Report message to a moderator
FUDForum. Page generated in 0.01799 seconds
