Home » Eclipse Projects » Memory Analyzer » Parsing Heap Dump Error in MAT
Parsing Heap Dump Error in MAT [message #897390] Tue, 24 July 2012 00:15 Go to next message
Mustafa Cayci is currently offline Mustafa CayciFriend
I am using Windows 7 64Bit.
I have Eclipse
Eclipse Platform
Version: 3.6.2
Build id: M20110210-1200
I have MAT version 1.2.
I have a simple code that dumps heap
public class Main {
* @param args
// TODO Auto-generated method stub
List<String> list = new ArrayList<String>();
while (1<2){
list.add("OutOfMemoryError soon");
When I tried to open in MAT, I am getting below
An internal error occurred during: "Parsing heap dump from 'D:\workspace\8032.hprof'".
allocLargeObjectOrArray: [J, size 695654576
THank you for your help.
Mustafa
Re: Parsing Heap Dump Error in MAT [message #897914 is a reply to message #897390] Wed, 25 July 2012 12:31 Go to previous message
Jonathan Lawrence is currently offline Jonathan LawrenceFriend
Hi Mustafa,
I am not able to reproduce the exact symptoms you are seeing. Can you provide some more details:
- What JVM version are you using with your Eclipse to run the test which produces the dump?
- What maximum heap size (-Xmx) are you using for your test application?
- What is the size of the .hprof dump which is written when your test application goes OutOfMemory?
- How much physical memory do you have available on your test machine?
Have you tried increasing the available heap size for Memory Analyzer (in the file MemoryAnalyzer.ini) change the entry -Xmx1024m to -Xmx4G or larger depending on the amount of memory available on your system.
Regards Jonathan.
Previous Topic:Help! com.ibm.j9ddr.InvalidDataTypeException: U_32 contains value larger than Integer.MAX_VALUE
Next Topic:Object references
Current Time: Sun Jul 25 17:24:35 GMT 2021
Powered by FUDForum. Page generated in 0.01458 seconds
