Home » Modeling » EMF » EMF/XSD invalid xml
EMF/XSD invalid xml [message #897314] Mon, 23 July 2012 14:55 Go to next message
Dennis Melzer is currently offline Dennis MelzerFriend
I generating an EMF Model using XML Schema (XSD). But the xsd:sequence tag is observed wrong.
I loading a config.xml:
<config>
    <name>Name</name>
    <tests>
        <test>Test</test>
    </tests>
</config>
and save it in a config1.xml. Resultat:
<config>
    <tests>
        <test>Test</test>
    </tests>
    <name>Name</name>
</config>
TestMain
public class TestMain
     * @param args
    public static void main(String[] args)
        OutputPackageImpl.init();
        OutputXMLProcessor processor = new OutputXMLProcessor();
        // Create a load resource
        Resource xmlResource2 = new OutputResourceFactoryImpl().createResource(null);
        try
            Resource xmlResource = processor.load("config.xml", null);
            xmlResource2.getContents().add(xmlResource.getContents().get(0));
            processor.save(new FileOutputStream(new File("config1.xml")), xmlResource2, null);
        catch (IOException e)
            e.printStackTrace();
Why is the <name> tag at the end of the file. So the xml is invalid.
I think the problem is the xsd:extension
    <xsd:complexType name="config">
        <xsd:complexContent>
            <xsd:extension base="tns:abstractConfig">
                <xsd:sequence>
                    <xsd:element name="tests" type="tns:..." />
                </xsd:sequence>
            </xsd:extension>
        </xsd:complexContent>
    </xsd:complexType>
[Updated on: Mon, 23 July 2012 15:14]
Report message to a moderator
Re: EMF/XSD invalid xml [message #897373 is a reply to message #897314] Mon, 23 July 2012 20:02 Go to previous message
It's impossible to comment on this without information about your schema.
On 23/07/2012 4:56 PM, Sir Wayne wrote:
> Hello,
> <config>
> <name>Name</name>
> <tests>
> <test>Test</test>
> </tests>
> </config>
> <config>
> <tests>
> <test>Test</test>
> </tests>
> <name>Name</name>
> </config>
> TestMain
> * @param args
> try
Previous Topic:Problem accessing resources in other depending projects
Next Topic:Transform exiting model and save to .uml
Current Time: Wed Jan 22 13:25:23 GMT 2020
Powered by FUDForum. Page generated in 0.01500 seconds
