Re: Unable to run gen_MyModel.launch [message #897198 is a reply to message #897163] |
Mon, 23 July 2012 06:42   |
Henrik Rentz-Reichert Messages: 261 Registered: July 2009 |
Hi Anil,
we haven't been aware of this problem until last week when we realized that also our build process at eclipse.org picks up version
2.3 of Xtext.
All people who currently use eTrice have Xtext 2.1.1 installed and thus had no problems.
This is what I also recommend to you.
Please un-install the Xtext 2.3 version (you can do so by choosing Help > About Eclipse > Installation Details, then in the
"Installed Software" tab mark all Xtext, Xtend and Xbase features, then press Uninstall...).
After that you can install Xtext 2.1.1 from
http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases/
Sorry for the inconvenience.
-Henrik
Am 22.07.2012 21:47, schrieb Anil Bhatia:
> Setup information:
> Installed 0.2.0 M2 release of eTrice:
> http://download.eclipse.org/etrice/updates/milestones/S-0.2.0-M2.201205211000
> This required 'bundle org.eclipse.xtext.xtend2.lib 2.1.1'.
> so, I also provided "http_colon_//download.itemis.de/updates/" and checked "Contact all update sites during install to find
> required software".
> This perhaps led to latest xtext (2.3) getting installed, but I guess that should not matter, because installation finished
> without any problem.
> Problem Description:
> I am attempting "Hello world" example given at http://www.eclipse.org/etrice/documentation/doc/etrice.html
> When I attempt to run gen_MyModel.launch, it is not able to locate org.eclipse.xtext.parser.IEncodingProvider implementation.
> I get the following exact error message:
> An internal error occurred during: "Launching gen_MyModel".
> Guice creation errors:
> 1) No implementation for org.eclipse.xtext.parser.IEncodingProvider was bound.
> while locating org.eclipse.xtext.parser.IEncodingProvider
> for field at org.eclipse.xtext.generator.JavaIoFileSystemAccess.encodingProvider(Unknown Source)
> while locating org.eclipse.xtext.generator.JavaIoFileSystemAccess
> for field at org.eclipse.etrice.generator.base.AbstractGenerator.fileAccess(Unknown Source)
> at org.eclipse.etrice.generator.java.setup.GeneratorModule.configure(GeneratorModule.java:37)
> 2) No implementation for org.eclipse.xtext.parser.IEncodingProvider was bound.
> for field at org.eclipse.etrice.generator.doc.gen.InstanceDiagramGen.fileAccess(Unknown Source)
> while locating org.eclipse.etrice.generator.doc.gen.InstanceDiagramGen
> for field at org.eclipse.etrice.generator.doc.gen.MainGen.instanceDiagramGen(Unknown Source)
> while locating org.eclipse.etrice.generator.doc.gen.MainGen
> for field at org.eclipse.etrice.generator.java.Main.mainDocGenerator(Unknown Source)
> 3) No implementation for org.eclipse.xtext.parser.IEncodingProvider was bound.
> for field at org.eclipse.etrice.generator.generic.PrepareFileSystem.fileAccess(Unknown Source)
> while locating org.eclipse.etrice.generator.generic.PrepareFileSystem
> for field at org.eclipse.etrice.generator.doc.gen.MainGen.prepFS(Unknown Source)
> 4) No implementation for org.eclipse.xtext.parser.IEncodingProvider was bound.
> for field at org.eclipse.etrice.generator.doc.gen.DocGen.fileAccess(Unknown Source)
> while locating org.eclipse.etrice.generator.doc.gen.DocGen
> for field at org.eclipse.etrice.generator.doc.gen.MainGen.docGen(Unknown Source)
> 5) No implementation for org.eclipse.xtext.parser.IEncodingProvider was bound.
> for field at org.eclipse.etrice.generator.java.gen.DataClassGen.fileAccess(Unknown Source)
> while locating org.eclipse.etrice.generator.java.gen.DataClassGen
> for field at org.eclipse.etrice.generator.java.gen.MainGen.dataClassGen(Unknown Source)
> at org.eclipse.etrice.generator.java.setup.GeneratorModule.configure(GeneratorModule.java:38)
> 6) No implementation for org.eclipse.xtext.parser.IEncodingProvider was bound.
> for field at org.eclipse.etrice.generator.java.gen.ProtocolClassGen.fileAccess(Unknown Source)
> while locating org.eclipse.etrice.generator.java.gen.ProtocolClassGen
> for field at org.eclipse.etrice.generator.java.gen.MainGen.protocolClassGen(Unknown Source)
> 7) No implementation for org.eclipse.xtext.parser.IEncodingProvider was bound.
> for field at org.eclipse.etrice.generator.java.gen.ActorClassGen.fileAccess(Unknown Source)
> while locating org.eclipse.etrice.generator.java.gen.ActorClassGen
> for field at org.eclipse.etrice.generator.java.gen.MainGen.actorClassGen(Unknown Source)
> 8) No implementation for org.eclipse.xtext.parser.IEncodingProvider was bound.
> for field at org.eclipse.etrice.generator.java.gen.SubSystemClassGen.fileAccess(Unknown Source)
> while locating org.eclipse.etrice.generator.java.gen.SubSystemClassGen
> for field at org.eclipse.etrice.generator.java.gen.MainGen.subsystemClassGen(Unknown Source)
> 9) No implementation for org.eclipse.xtext.parser.IEncodingProvider was bound.
> for field at org.eclipse.etrice.generator.java.gen.SubSystemRunnerGen.fileAccess(Unknown Source)
> while locating org.eclipse.etrice.generator.java.gen.SubSystemRunnerGen
> for field at org.eclipse.etrice.generator.java.gen.MainGen.subsystemRunnerGen(Unknown Source)
> 10) No implementation for org.eclipse.xtext.parser.IEncodingProvider was bound.
> for field at org.eclipse.etrice.generator.java.gen.MainGen.prepFS(Unknown Source)
> 10 errors
FUDForum. Page generated in 0.05341 seconds
