Home » Eclipse Projects » Remote Application Platform (RAP) » Nebula Grid plug-in(JAR) Download Address?
Re: Nebula Grid plug-in Download Address? [message #896847 is a reply to message #896843] |
Fri, 20 July 2012 06:44 |
ocean xue Messages: 107 Registered: November 2011 |
Hi, Ivan
org.eclipse.rap.nebula.widgets.grid add to the dependencies, run error?
rap runtime to 1.5 release.
snippet:
package com.yidatec.eoffice.om.project.form.dialogs;
import org.eclipse.nebula.widgets.grid.Grid;
import org.eclipse.nebula.widgets.grid.GridColumn;
import org.eclipse.nebula.widgets.grid.GridColumnGroup;
import org.eclipse.nebula.widgets.grid.GridItem;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
public class OP003Step04Dialog extends Composite {
private static final long serialVersionUID = 1L;
* Create the composite.
* @param parent
* @param style
public OP003Step04Dialog(Composite parent, int style) {
super(parent, style);
setLayout(new GridLayout(1, false));
Grid grid = new Grid(this, SWT.BORDER | SWT.V_SCROLL | SWT.H_SCROLL);
grid.setHeaderVisible(true);
GridColumn column = new GridColumn(grid, SWT.NONE);
column.setText("Column 1");
column.setWidth(100);
GridColumnGroup columnGroup = new GridColumnGroup(grid, SWT.NONE);
columnGroup.setText("Column Group");
GridColumn column2 = new GridColumn(columnGroup, SWT.NONE);
column2.setText("Column 2");
column2.setWidth(60);
GridColumn column3 = new GridColumn(columnGroup, SWT.NONE);
column3.setText("Column 3");
column3.setWidth(60);
GridItem item1 = new GridItem(grid, SWT.NONE);
item1.setText("First Item");
item1.setText(1, "abc");
GridItem item2 = new GridItem(grid, SWT.NONE);
item2.setText("Second Item");
item2.setText(2, "def");
GridItem item3 = new GridItem(grid, SWT.NONE);
item3.setText("Third Item");
item3.setText(1, "xyz");
protected void checkSubclass() {
// Disable the check that prevents subclassing of SWT components
error msg:
Could not process server response:
Error: Error: Operation "create" on target "w501" of type "null" failed:
No Adapter for type rwt.widgets.Grid
Properties:
parent = w296
style = FULL_SELECTION,BORDER
appearance = tree
indentionWidth = 16
markupEnabled = false
bounds = 5,5,232,134
children =
tabIndex = 85
itemCount = 3
itemHeight = 26
itemMetrics = 0,0,100,5,0,5,90,5,0,1,100,60,105,0,105,50,105,0,2,160,60,165,0,165,50,165,0
columnCount = 3
headerHeight = 44
headerVisible = true
linesVisible = true
[Updated on: Fri, 20 July 2012 06:49] Report message to a moderator
Re: Nebula Grid plug-in Download Address? [message #896850 is a reply to message #896847] |
Fri, 20 July 2012 07:00 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Grid requires RAP from Git master (nightly build). Grid does not work
with RAP 1.5.
Best,
Ivan
On 7/20/2012 9:44 AM, ocean xue wrote:
> Hi, Ivan
> snippet:
> * * @param parent
> * @param style
> SWT.H_SCROLL);
> SWT.NONE);
> @Override
> error msg:
> Properties: parent = w296
> appearance = tree
> indentionWidth = 16
> children = tabIndex = 85
> itemCount = 3
> itemHeight = 26
> itemMetrics =
> columnCount = 3
> headerHeight = 44
> linesVisible = true
Ivan Furnadjiev
Twitter: @EclipseRAP
Current Time: Thu Apr 25 07:07:02 GMT 2024
Powered by FUDForum. Page generated in 0.04838 seconds
