Re: About code assistant. [message #898757 is a reply to message #896827] |
Fri, 27 July 2012 13:04 |
Simon Bernard Messages: 345 Registered: July 2009 |
In the last stable release (0.8):
The outline display only the first level local variable and the API you could describe with luadocumentor.
You should have content assist :
- on local variables.
- on global variables considered as preloaded in your execution environment. (like print in lua 5.1)
- on module documented with luadocumentor.
Did you try the execution environment feature ?
You could download and add the Lua 5.1 execution environment support to your project to enable autocompletion for lua 5.1.
HTH
[Updated on: Thu, 02 August 2012 15:38] Report message to a moderator
FUDForum. Page generated in 0.02566 seconds
