Home » Eclipse Projects » Eclipse 4 » Using own TranslationService for Application.e4xmi
Using own TranslationService for Application.e4xmi [message #896634] Thu, 19 July 2012 08:28 Go to next message
Stefan Klaus is currently offline Stefan KlausFriend
Hi there!
Is there any example of how to extend the TranslationService to use own implementation. I've already a internationalisation-bundle collecting the resource bundle and like to use it within the TranslationService to provide texts for the Application.e4xmi. I don't like to use the build in mechanism with "Externalize Strings" and a resource bundle in OSGI/l10n/... I like to use my own existing resources for the Application.e4xmi
Thanks for your help
Stefan
Re: Using own TranslationService for Application.e4xmi [message #896641 is a reply to message #896634] Thu, 19 July 2012 08:52 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
I've shown at various conference how this is done using Google
Translate. I'll try to publish a blog entry and come back to you.
Tom
Am 19.07.12 10:28, schrieb Stefan Mising name:
> Hi there!
> Application.e4xmi
> Stefan
Re: Using own TranslationService for Application.e4xmi [message #900009 is a reply to message #896641] Fri, 03 August 2012 12:28 Go to previous messageGo to next message
Thanks in advance.
Re: Using own TranslationService for Application.e4xmi [message #938857 is a reply to message #900009] Wed, 10 October 2012 08:10 Go to previous message
Ok, solved my Problem.
For all others here is my solution:
- Add a LifeCycleHandler as described here www.toedter.com/blog/?p=896
- Do your own Implementation of TranslationService by extending it
- Set your own Implementation for the TranslationService
@PostContextCreate
	public void initialConfiguration(IEclipseContext context) {
          context.set(TranslationService.class, new MyTranslationServiceImpl());
Done. Really simple...
Previous Topic:Core Expression Definition null/exists check?
Next Topic:Main menu
Current Time: Sat May 08 05:30:57 GMT 2021
Powered by FUDForum. Page generated in 0.02033 seconds
