Eclipse 3.8/rap 1.5 helpSystem problem [message #896564] |
Wed, 18 July 2012 22:18 |
Ana Tatavu Messages: 10 Registered: July 2009 |
I switched recently from RAP 1.4(Eclipse 3.7,jvm 1.6) to RAP 1.5 (eclipse 3.8, jvm 1.7)
In the 1.4 version of our RAP product help system is working fine, in 1.5 doesn't work anymore.
The help files are organized..
Plugin...
-src
-help
- html
Toc.xml
The extension point
<extension
point="org.eclipse.help.toc">
<toc
file="help/toc.xml"
primary="true">
</toc>
</extension>
The help is invoked by opening a browser:
IWorkbench workbench = PlatformUI.getWorkbench();
IWorkbenchBrowserSupport browserSupport = workbench.getBrowserSupport();
try
IWebBrowser browser = browserSupport.createBrowser("helpBrowser"); //$NON-NLS-1$
browser.openURL(getUrl());
catch (PartInitException e)
Activator.getDefault().logError(getClass(), e);
private static URL getUrl()
StringBuffer sb = RWT.getRequest().getRequestURL();
String urlString = sb.toString();
urlString = StringUtils.removeEnd(urlString, ApplicationConstants.APPLICATION_ROOT);
urlString = urlString + "/index.jsp";//$NON-NLS-1$
try
return new URL(urlString);
catch (MalformedURLException e)
throw new IllegalArgumentException("Failed to construct URL.");
When opening the url we got 404 message in RAP 1.5 only.
What can I do about it,
Thank you.
Ana
Re: Eclipse 3.8/rap 1.5 helpSystem problem [message #896607 is a reply to message #896564] |
Thu, 19 July 2012 07:06 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Ana,
we have a bug opened for this issue:
383867: The eclipse help system (helpSupport) UI does not work properly
in RAP 1.5
https://bugs.eclipse.org/bugs/show_bug.cgi?id=383867
Austin provided a help bundle patch in comment#2.
HTH,
Ivan
> Plugin...
> -src
> -help
> - html
> Toc.xml
> The extension point <extension
> <toc
> file="help/toc.xml"
> primary="true">
> </toc>
> </extension>
> try
> try
> URL."); }
> Thank you.
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Eclipse 3.8/rap 1.5 helpSystem problem [message #896729 is a reply to message #896709] |
Thu, 19 July 2012 14:05 |
Hi Ana,
I didn't investigate what is the problem, but from reading the code of
the proposed attached patch, it modifies *only* the original Eclipse
help bundles (not part of the RAP framework) in order to work correctly
with RAP. Without further investigation, I couldn't say if it's possible
to make the help system works again without these modifications. Are you
using the same Eclipse Help bundles that worked before, but not with 1.5?
Best,
Ivan
On 7/19/2012 4:11 PM, Ana Mising name wrote:
> Do you know when the fix will be incorporated into RAP?
> I am not sure if my company policy allows shipping with a patch
> applied outside of RAP itself development.
> Thank you,
> Ana
Ivan Furnadjiev
FUDForum. Page generated in 0.03913 seconds
