Home » Language IDEs » Java Development Tools (JDT) » templates broken in juno
templates broken in juno [message #896522] Wed, 18 July 2012 16:22 Go to next message
Palmer Eldritch is currently offline Palmer EldritchFriend
Member
Updated from indigo to juno via Help > Find updates (I added the juno repos)
Since then control+space fails on templates (like sysout) and SWT - I can't copy the message unfortunately (why?). The relevant part of the log (which as I now see has many other errors) is :
!ENTRY org.eclipse.jdt.ui 4 0 2012-07-18 19:04:52.572
!MESSAGE The 'org.eclipse.jdt.ui.TemplateProposalComputer' proposal computer from the 'org.eclipse.jdt.ui' plug-in did not complete normally. Unable to instantiate the extension.
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.jdt.ui" was unable to instantiate class "org.eclipse.jdt.internal.ui.text.java.TemplateCompletionProposalComputer".
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:186)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.jdt.internal.ui.text.java.CompletionProposalComputerDescriptor.createComputer(CompletionProposalComputerDescriptor.java:308)
	at org.eclipse.jdt.internal.ui.text.java.CompletionProposalComputerDescriptor.getComputer(CompletionProposalComputerDescriptor.java:275)
	at org.eclipse.jdt.internal.ui.text.java.CompletionProposalComputerDescriptor.sessionStarted(CompletionProposalComputerDescriptor.java:418)
	at org.eclipse.jdt.internal.ui.text.java.CompletionProposalCategory.sessionStarted(CompletionProposalCategory.java:379)
	at org.eclipse.jdt.internal.ui.text.java.ContentAssistProcessor$CompletionListener.assistSessionStarted(ContentAssistProcessor.java:117)
	at org.eclipse.jface.text.contentassist.ContentAssistant.fireSessionBeginEvent(ContentAssistant.java:2221)
	at org.eclipse.jface.text.contentassist.ContentAssistant.prepareToShowCompletions(ContentAssistant.java:1696)
	at org.eclipse.jface.text.contentassist.ContentAssistant.showPossibleCompletions(ContentAssistant.java:1661)
	at org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor$AdaptedSourceViewer.doOperation(CompilationUnitEditor.java:183)
	at org.eclipse.ui.texteditor.ContentAssistAction$1.run(ContentAssistAction.java:82)
	at org.eclipse.ui.texteditor.ContentAssistAction.run(ContentAssistAction.java:80)
	at org.eclipse.ui.texteditor.RetargetTextEditorAction.run(RetargetTextEditorAction.java:237)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
	at org.eclipse.jface.commands.ActionHandler.execute(ActionHandler.java:119)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:276)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:494)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:545)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:366)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:313)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:82)
	at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1052)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
	at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1104)
	at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1100)
	at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1521)
	at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4640)
	at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.java:345)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4528)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
	at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2546)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3756)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
	at org.eclipse.jdt.internal.ui.JavaPlugin.getTemplateContextRegistry(JavaPlugin.java:820)
	at org.eclipse.jdt.internal.ui.text.java.TemplateCompletionProposalComputer.<init>(TemplateCompletionProposalComputer.java:46)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
	at java.lang.reflect.Constructor.newInstance(Unknown Source)
	at java.lang.Class.newInstance0(Unknown Source)
	at java.lang.Class.newInstance(Unknown Source)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
	... 72 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2012-07-18 19:04:52.572
!MESSAGE Plug-in "org.eclipse.jdt.ui" was unable to instantiate class "org.eclipse.jdt.internal.ui.text.java.TemplateCompletionProposalComputer".
!STACK 0
!ENTRY org.eclipse.jdt.ui 4 0 2012-07-18 19:05:03.369
!MESSAGE The 'org.eclipse.jdt.ui.swtBuilderCompletionProposalComputer' proposal computer from the 'org.eclipse.jdt.ui' plug-in did not complete normally. Unable to instantiate the extension.
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.jdt.ui" was unable to instantiate class "org.eclipse.jdt.internal.ui.text.java.SWTTemplateCompletionProposalComputer".
	at org.eclipse.jdt.internal.ui.text.java.SWTTemplateCompletionProposalComputer.<init>(SWTTemplateCompletionProposalComputer.java:137)
	... 72 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2012-07-18 19:05:03.369
!MESSAGE Plug-in "org.eclipse.jdt.ui" was unable to instantiate class "org.eclipse.jdt.internal.ui.text.java.SWTTemplateCompletionProposalComputer".
!STACK 0
eclipse-kepler JEE
Win7 x64
Re: templates broken in juno [message #896761 is a reply to message #896522] Thu, 19 July 2012 15:58 Go to previous messageGo to next message
Stephan Herrmann is currently offline Stephan HerrmannFriend
The relevant part seems to be this:
I suggest searching bugzilla for something that looks similar.
If you can't find anything, it might be worth filing a new bug against JDT/UI.
best,
Stephan
Re: templates broken in juno [message #897087 is a reply to message #896761] Sat, 21 July 2012 14:49 Go to previous message
Member
Thanks - will do - to be noted that all was fine in Indigo - it is related to the update process
Bug : https://bugs.eclipse.org/bugs/show_bug.cgi?id=385665
eclipse-kepler JEE
Win7 x64
Previous Topic:Juno run shortcuts don't work
Next Topic:@NonNull Lists
Current Time: Tue Apr 16 09:03:51 GMT 2024
Powered by FUDForum. Page generated in 0.96935 seconds
