Home » Modeling » TMF (Xtext) » Server-side parsing concepts
Server-side parsing concepts [message #896399] Wed, 18 July 2012 09:42 Go to next message
Martin Buchheim is currently offline Martin BuchheimFriend
currently, I'm working on a project involving Xtext (2.3.0) in several contexts:
1- First, user's should be able to create files using my Xtext grammar in an embedded Xtext-editor, with syntax highlighting etc. => done using the new "EmbeddedEditorFactory"-approach, thank you for adding this Smile
2- The files will be transfered to and persisted on a server. This will simply store the editor-contents as a string in a database => done
3- On request, the contents should be taken from the database and be "evaluated" on the server-side
This third part currently gives me a few headaches. What I basically try to achieve is to retrieve the editor-content-string from the database, parse it through Xtext and retrieve the fitting EMF-model structure as it was generated by the grammar.
I've read in the documentation that Xtext should be running in a non-equinox context (which I have on the server) using the "StandaloneSetup" and injector, which is fine (and I'm already using this for the embedded editor).
However, I couldn't find any information on how to go on. Is it shomehow possible to get the IParser injected, pass the string through a StringReader and get the resulting structure in a IParseResult? That's exactly what I'd require, but I don't know how I could actually retrieve the initial parser.
Any hints if/how that coule be done would be greatly appreciated.
Thank you,
Martin
Re: Server-side parsing concepts [message #896423 is a reply to message #896399] Wed, 18 July 2012 11:30 Go to previous message
Jan Koehnlein is currently offline Jan KoehnleinFriend
Use the EMF Resource API to load and parse models:
1) call <yourlanguge>StandaloneSetup.doSetup() to create the injector
and register the language to the EMF registries
2) create an XtextResourceSet
3) load the file as a resource into the resource set
4) access the resource's contents. This will be the AST
Am 18.07.12 11:42, schrieb Martin Buchheim:
> Hello,
> contexts:
> the new "EmbeddedEditorFactory"-approach, thank you for adding this :)
> the initial parser.
> Thank you,
> Martin
Get professional support from the Xtext committers at www.typefox.io
Previous Topic:importURI 101
Next Topic:NPE opening external files
Current Time: Mon Mar 30 11:03:40 GMT 2020
Powered by FUDForum. Page generated in 0.02957 seconds
