Home » Archived » Buckminster » Adding source features to category.xml
Re: Adding source features to category.xml [message #896313 is a reply to message #896250] |
Wed, 18 July 2012 02:54 |
Hi Lorenzo,
I think the source feature will be named my.proj.source.feature rather than my.proj.feature.source. In other respects I
don't see anything wrong with your setup. We're doing the same thing in Buckminster and it works as expected.
HTH,
- thomas
On 07/17/2012 07:22 PM, Lorenzo Bettini wrote:
> Hi
> Buckminster already generates source plugins and features which is nice! Now I'd like to add the source features to my
> category.xml so that they appear as belonging to the main category (while by default they appear as non categorized).
> In order to do that I added to my category.xml besides my main feature, e.g.,
> <feature id="my.proj.feature">
> <category name="mycategory"/>
> </feature>
> also the source feature (which is not in the workspace, it is actually generated only by Buckminster):
> <feature id="my.proj.feature.source">
> </feature>
> However, the generated site.p2 still does not show the source feature in the category...
> am I doing something wrong?
> thanks in advance
> Lorenzo
Re: Adding source features to category.xml [message #896378 is a reply to message #896313] |
Wed, 18 July 2012 08:39 |
I think <feature-name>.source is the correct name.
For example following works for me:
<site>
<feature id="org.xtext.example.mydsl.sdk" version="0.0.0">
<category name="main"/>
</feature>
<feature id="org.xtext.example.mydsl.sdk.source" version="0.0.0">
<category name="main.source"/>
</feature>
<category-def name="main" label="Mydsl"/>
<category-def name="main.source" label="Source for Mydsl"/>
</site>
You can also look into the metadata of the generated p2 repositoy to track down what is going wrong.
+Dennis Huebner
Get professional support from the Xtext committers at www.typefox.io
Re: Adding source features to category.xml [message #896394 is a reply to message #896378] |
Wed, 18 July 2012 09:23 |
That depends actually. If the name ends with .feature, then the name of the source feature will become .source.feature
- thomas
> <site>
> </feature>
> </feature>
> </site>
Re: Adding source features to category.xml [message #896406 is a reply to message #896397] |
Wed, 18 July 2012 10:05 |
> Very interesting, there is probably a very good reason for such kind of behavior.
> That may be a bit confusing for buckminster noobs :)
At the time when this was implemented, this naming scheme seemed to be very common. Hence the logic that implements it.
Some new naming rules were established when p2 came around though, which I think has made people move away from the
older habit of using a .feature suffix for features. P2 adds '.feature.group' and 'feature.jar' to the respective p2
IU's and names ending with .feature.feature.group and feature.feature.jar might seem a bit strange.
- thomas
Re: Adding source features to category.xml [message #896629 is a reply to message #896406] |
Thu, 19 July 2012 08:11 |
>> of behavior.
> very common. Hence the logic that implements it. Some new naming rules
> people move away from the older habit of using a .feature suffix for
> p2 IU's and names ending with .feature.feature.group and
So, it would be better NOT to add .feature to feature's id?
cheers
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
Current Time: Wed Apr 24 21:54:53 GMT 2024
Powered by FUDForum. Page generated in 0.04332 seconds
