Home » Eclipse Projects » Rich Client Platform (RCP) » Automating the deployment process of plugin
Automating the deployment process of plugin [message #896188] Tue, 17 July 2012 14:08 Go to next message
becks m is currently offline becks mFriend
Member
I have an eclipse plugin, when I deploy it, I use a feature project then export through the wizard to get zip file to install in any eclipse based app.
How can I automate this ?
I want the whole process to run automatically.
Re: Automating the deployment process of plugin [message #896260 is a reply to message #896188] Tue, 17 July 2012 18:54 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
You automate building a feature/plugin using PDE build. http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.pde.doc.user%2Ftasks%2Fpde_feature_build.htm&cp=4_2_0_1
You can automate installing features into your current eclipse using the p2 director, http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Fguide%2Fp2_director.html&cp=2_0_20_2
PW
Re: Automating the deployment process of plugin [message #897862 is a reply to message #896260] Wed, 25 July 2012 10:29 Go to previous messageGo to next message
Member
Thanks Paul,
but I get this error during feature installation
is there something should I do ?
!ENTRY org.eclipse.equinox.p2.director 4 1 2012-07-25 12:26:01.685
!MESSAGE Cannot complete the install because one or more required items could not be found.
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2012-07-25 12:26:01.685
!MESSAGE Software being installed: program 1.0.6 (com.myprog.feature.feature.group 1.0.6)
!MESSAGE Missing requirement: program 1.0.6 (com.myprog.feature.feature.group 1.0.6) requires 'org.eclipse.core.runtime 3.7.0' but it could not be found
[Updated on: Wed, 25 July 2012 10:31]
Report message to a moderator
Re: Automating the deployment process of plugin [message #902844 is a reply to message #897862] Mon, 20 August 2012 18:03 Go to previous messageGo to next message
What org.eclipse.core.runtime do you have in the RCP app you are trying to install into?
PW
Re: Automating the deployment process of plugin [message #902845 is a reply to message #897862] Mon, 20 August 2012 18:03 Go to previous messageGo to next message
What version of org.eclipse.core.runtime do you have in your application you are trying to install into?
PW
Re: Automating the deployment process of plugin [message #902846 is a reply to message #897862] Mon, 20 August 2012 18:04 Go to previous messageGo to next message
What version of org.eclipse.core.runtime is already in your app?
PW
Re: Automating the deployment process of plugin [message #902847 is a reply to message #897862] Mon, 20 August 2012 18:04 Go to previous messageGo to next message
PW
Re: Automating the deployment process of plugin [message #902848 is a reply to message #897862] Mon, 20 August 2012 18:05 Go to previous messageGo to next message
What version of org.eclipse.core.runtime do you already have in your app?
PW
Re: Automating the deployment process of plugin [message #902851 is a reply to message #902848] Mon, 20 August 2012 18:08 Go to previous message
Sorry, I was having replicator problems. All fixed now.
PW
Previous Topic:External jar class cannot be resolved
Next Topic:adding option to eclipse from my plugin
Current Time: Tue Nov 05 03:32:49 GMT 2024
Powered by FUDForum. Page generated in 0.04649 seconds
