Home » Eclipse Projects » BIRT » Reg dynamic parameter (Reg dynamic parameter )
Reg dynamic parameter [message #896010] Mon, 16 July 2012 21:47 Go to next message
A R is currently offline A RFriend
For one specific requirement I need to come up a quesry as follows for my dataset.
select * FROM ASSET_REQUEST_29 UNION ALL
select * FROM ASSET_REQUEST_31 UNION ALL
select * FROM ASSET_REQUEST_32 UNION ALL
select * FROM ASSET_REQUEST_33 UNION ALL
select * FROM ASSET_REQUEST_34 UNION ALL
select * FROM ASSET_REQUEST_36
Problem here is there is possibility of that ifin future new version of the "ASSET_REQUEST" is created like "ASSET_REQUEST_37, ASSET_REQUEST_38" then my report won't be able to capture the informaiton from the same. I need to modify the report.
Please suggest me , how can i be able to achieve the approach where I can dynamically over come this issue.
Let me know if I need to provide any details further.
AR
Re: Reg dynamic parameter [message #896041 is a reply to message #896010] Tue, 17 July 2012 02:55 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Do you have a table that stores the highest number?
Jason
> my dataset.
> Thanks
> AR
Re: Reg dynamic parameter [message #896236 is a reply to message #896041] Tue, 17 July 2012 16:33 Go to previous messageGo to next message
No Jason, besides the versions are random sometime depending on architecture. I mean sometimes we may disbale few versions depending on situation.
For your question of highest number, I assume I can caluculate the same in same dataset or in another dataset...
Please let me know, if I am missing answer to ur Q'n
AR
Re: Reg dynamic parameter [message #896244 is a reply to message #896236] Tue, 17 July 2012 17:01 Go to previous messageGo to next message
You have a couple of options. Before you use the main dataset you could
add a hidden table that returns the all of the tables you want to union
and then store these in js vars which you then access in the beforeOpen
of your main dataset to modify the query. Or call the data engine api
directly and get the values to modify your query. I am attaching a
simple data engine api example in the beforeFactory.
Jason
> situation.
> Thanks
> AR
Re: Reg dynamic parameter [message #896786 is a reply to message #896244] Thu, 19 July 2012 18:45 Go to previous messageGo to next message
Thanks for the response Jason. I am not clear with how to proceed the suggested option.
I have attached the modified example. In which I have created the dataset where I can access all the tables that I need to union. Creted parameter and variable, included one table where I have included the view_name.
AR
Re: Reg dynamic parameter [message #896787 is a reply to message #896786] Thu, 19 July 2012 18:48 Go to previous messageGo to next message
AR
Re: Reg dynamic parameter [message #896806 is a reply to message #896787] Thu, 19 July 2012 21:20 Go to previous messageGo to next message
In your main data set that will get the data you will need to enter a
query that gets all the expected column names. Say like:
Then in the beforeFactory you will create the rest of the query like:
mymodquery = "";
var ri = qr.getResultIterator( );
while ( ri.next( ) )
mymodquery = mymodquery + " UNION ALL ";
col1=ri.getValue("PRODUCTLINE");
mymodquery = mymodquery + " select * from " + col1
Then in the beforeOpen of the main data set put in
this.queryText = this.queryText + mymodquery;
Jason
> Thanks
> AR
Re: Reg dynamic parameter [message #897641 is a reply to message #896806] Tue, 24 July 2012 21:02 Go to previous messageGo to next message
Hi Jaosn - thanks for the response.
I am sorry for my ignorance. I tried the same approach but I am not able to understand how can I use of the dynamic query that script created. I am ataching the rpt design for the reference,which I am working.
AR
Re: Reg dynamic parameter [message #897643 is a reply to message #896806] Tue, 24 July 2012 21:04 Go to previous messageGo to next message
AR
Re: Reg dynamic parameter [message #897657 is a reply to message #897643] Tue, 24 July 2012 23:52 Go to previous messageGo to next message
Hello Jason, I am sorry. Now only I am getting slowy the above solution won't help me to achieve the requirement. I am trying this option to achieve the issue :
http://www.eclipse.org/forums/index.php/m/895607/#msg_895607
Please find the attahed qry for the dataset, that gives a static solution. Please let me know if any concerns.
AR
[Updated on: Tue, 14 August 2012 18:33]
Report message to a moderator
Re: Reg dynamic parameter [message #898610 is a reply to message #897657] Thu, 26 July 2012 21:17 Go to previous messageGo to next message
Does the static solution address all your needs?
Jason
> Thanks
> AR
Re: Reg dynamic parameter [message #898807 is a reply to message #898610] Fri, 27 July 2012 17:23 Go to previous messageGo to next message
Yes Jason, it caters aall my requirements.
AR
Re: Reg dynamic parameter [message #899929 is a reply to message #898807] Thu, 02 August 2012 22:22 Go to previous messageGo to next message
Hi Jason - I am not able to workout the solution. Please suggest.
AR
Re: Reg dynamic parameter [message #900075 is a reply to message #899929] Fri, 03 August 2012 19:55 Go to previous message
I am not certain on the issue you are having. I thought from your last
post you had it working.
Jason
> Thanks
> AR
Previous Topic:Custom aggregation through the plugin via eclipse data extension point
Next Topic:Does birt support nested axis label
Current Time: Thu Dec 09 07:41:19 GMT 2021
Powered by FUDForum. Page generated in 0.03315 seconds
