Home » Modeling » EMF » [xcore] refering to classes in non XCore ecore models
Re: [xcore] refering to classes in non XCore ecore models [message #896068 is a reply to message #896052] |
Tue, 17 July 2012 07:07 |
Joel Greenyer Messages: 170 Registered: July 2009 |
Hi Ed,
Works. Thanks for the explanation.
Maybe you should add this to your XCore wiki article... I'm sure others will come across this.
Ciao
Joel
On 17.07.2012 07:28, Ed Merks wrote:
> Joel,
> Comments below.
> On 16/07/2012 8:24 PM, Joel Greenyer wrote:
>> Hi,
>> in an XCore model/plug-in I'm trying to refer to another EClass modeled in a regular .ecore file in another plugin.
>> The former plug-in depends on the latter, the import seems to work, but in the line "refers" (see example below), it says
>> "Multiple markers at this line - A generic type in this context must refer to a classifier or a type parameter -
>> Couldn't resolve reference to GenBase 'Blub'."
>> ------Example------
>> package org.example.coolpackage
>> import org.example.anothercoolpackage.Blub
>> class Bla{
>> refers Blub b
>> ------EndExample------
>> Am I missing a reference to the ecore model / it's genmodel?
> The other model's project must have an Xtext nature (File->Configure->Add Xtext nature) in order for Xtext's indexing infrastructure to index it and that's needed in order for Xcore to know about the indexed *.genmodel resources in that project. Failing that, the *.genmodel resources need to be on the classpath, which is the case only when a bundle is properly deployed as runtime bundle to include the model folder in the bundle and where the classes are in "." rather than "bin" as they are at development time. It's an annoying and long standing issue that the PDE doesn't put everything that's on the actual runtime path after deployment on the classpath at development time...
>> Thanks for helping
>> Joel
Re: [xcore] refering to classes in non XCore ecore models [message #896219 is a reply to message #896068] |
Tue, 17 July 2012 15:39 |
I have another problem.
If I say
class Bla extends Blub{
I have the problem that in the generated Package class there is a line
int BLA_OPERATION_COUNT = AnothercoolpackagePackage.BLUB_OPERATION_COUNT + 0;
where "BLUB_OPERATION_COUNT cannot be resolved or is not a field", i.e., the ...__OPERATION_COUNT field is not generated for the class in the package generated from standard ecore-&genmodel.
Is there anything I can do about that?
Joel
On 17.07.2012 09:07, Joel Greenyer wrote:
> Hi Ed,
> Ciao
> Joel
>> Joel,
>> Comments below.
>>> Hi,
>>> ------Example------
>>> class Bla{
>>> refers Blub b
>>> Thanks for helping
>>> Joel
Re: [xcore] refering to classes in non XCore ecore models [message #896342 is a reply to message #896219] |
Wed, 18 July 2012 06:54 |
Ed Merks Messages: 33113 Registered: July 2009 |
Joel,
The base model must support Operation Reflection (it's false by default)
or the derived model must not (it's true by default for Xcore models).
As you probably know, you can use the properties view to set such things
for your Xcore model to produce the necessary @GenModel annotations.
On 17/07/2012 5:39 PM, Joel Greenyer wrote:
> If I say
> Thanks
> Joel
>> Hi Ed,
>> Ciao
>> Joel
>>> Joel,
>>> Comments below.
>>>> Hi,
>>>> ------Example------
>>>> class Bla{
>>>> refers Blub b
>>>> Thanks for helping
>>>> Joel
Ed Merks
Re: [xcore] refering to classes in non XCore ecore models [message #896508 is a reply to message #896342] |
Wed, 18 July 2012 15:12 |
great.
Thanks!
On 18.07.2012 08:54, Ed Merks wrote:
> Joel,
> The base model must support Operation Reflection (it's false by default) or the derived model must not (it's true by default for Xcore models). As you probably know, you can use the properties view to set such things for your Xcore model to produce the necessary @GenModel annotations.
>> Hi,
>> If I say
>> Thanks
>> Joel
>>> Hi Ed,
>>> Ciao
>>> Joel
>>>> Joel,
>>>> Comments below.
>>>>> Hi,
>>>>> ------Example------
>>>>> class Bla{
>>>>> refers Blub b
>>>>> Thanks for helping
>>>>> Joel
Re: [xcore] refering to classes in non XCore ecore models [message #898888 is a reply to message #898873] |
Sat, 28 July 2012 19:54 |
Max,
At a glance, I suspect that the base model doesn't support reflective
operation invocation while your derived model, by default, does. Adding
@GenModel(operationReflection="false") on the package declaration should
avoid that.
On 28/07/2012 7:50 PM, Max Goltzsche wrote:
> Hello,
> I've got a similar problem extending
> TypesPackage::JvmIdentifiableElement.
> The following xcore class is valid:
> ---- BEGIN XCORE EXAMPLE ----
> class MyCustomJvmIdentifiableElement extends JvmIdenfiableElement {
> String name
> op String getIdentifier() {
> name
> op String getSimpleName() {
> name
> op String getQualifiedName() {
> name
> op String getQualifiedName(char separator) {
> name
> ---- END XCORE EXAMPLE ----
> But the generated Java function int eDerivedOperationID(int, Class<?>)
> contains errors: The int constants representing the super type's
> operations do not exist:
> TypesPackage.JVM_IDENTIFIABLE_ELEMENT___GET_IDENTIFIER,
> TypesPackage.JVM_IDENTIFIABLE_ELEMENT___GET_SIMPLE_NAME,
> TypesPackage.JVM_IDENTIFIABLE_ELEMENT___GET_QUALIFIED_NAME,
> TypesPackage.JVM_IDENTIFIABLE_ELEMENT___GET_QUALIFIED_NAME__CHAR
> How to solve this error?
> best regards,
> Max
Ed Merks
Current Time: Fri Mar 29 09:36:37 GMT 2024
Powered by FUDForum. Page generated in 0.02943 seconds
