Re: Not Able to Run Servlet in eclispe [message #895921 is a reply to message #895794] |
Mon, 16 July 2012 13:50 |
On 7/15/2012 11:24 PM, Jagdeep Gupta wrote:
> HI,
> I have my projects in two directory :
> d:/Jagdeep and d:/Ganesh/Java_ex
> in later directory when I run the servlet with help of eclipse it run
> and show output but in d:/jagdeep directory it always throw an error
> that tomcat can not be started as the port 8080,8005,8009 is being used
> by other application.
> Can anyone help me to resolve this?
If you're running Tomcat from within Eclipse as you seem to say here,
you modify the port settings by double-clicking this Tomcat in the
Servers view of the Eclipse workbench.
Re: Not Able to Run Servlet in eclispe [message #896182 is a reply to message #896028] |
Tue, 17 July 2012 14:00 |
On 7/16/2012 7:57 PM, Jagdeep Gupta wrote:
> Thanks for replying,
> Yes I am using Tomcat through eclipse.
> But at the same time I am able to run in the another folder why it is so?
> and If I have to change the port number then what new port number should
> I give?
You may use just about any port number. Right now, I'm using 8005/8000/8009.
FUDForum. Page generated in 0.08462 seconds
