Leak suspect report [message #895768] |
Sun, 15 July 2012 21:38 |
Ashfaque Mohammad Messages: 3 Registered: November 2011 |
Leak suspect report shows follwoing as the suspects. But my question is about the message at the bottom, which says that these are referenced from a WeakHashMap, so shoudn't these be garbage collected during the Full-GC phase?
279 instances of "hudson.plugins.cobertura.targets.CoverageResult", loaded by "java.net.URLClassLoader @ 0x2ac774988cc0" occupy 3,766,994,368 (19.67%) bytes.
Biggest instances:
•hudson.plugins.cobertura.targets.CoverageResult @ 0x2aca4681d3b0 - 402,065,440 (2.10%) bytes.
•hudson.plugins.cobertura.targets.CoverageResult @ 0x2ac956dfd440 - 401,219,936 (2.10%) bytes.
•hudson.plugins.cobertura.targets.CoverageResult @ 0x2acac9dc2670 - 399,164,488 (2.08%) bytes.
•hudson.plugins.cobertura.targets.CoverageResult @ 0x2ac927ac23a8 - 398,056,168 (2.08%) bytes.
•hudson.plugins.cobertura.targets.CoverageResult @ 0x2ac9f06b5cd8 - 392,134,000 (2.05%) bytes.
•hudson.plugins.cobertura.targets.CoverageResult @ 0x2ac97add0390 - 392,085,544 (2.05%) bytes.
•hudson.plugins.cobertura.targets.CoverageResult @ 0x2ac8c300ffe0 - 375,067,880 (1.96%) bytes.
•hudson.plugins.cobertura.targets.CoverageResult @ 0x2ac7ef77b030 - 320,967,496 (1.68%) bytes.
These instances are referenced from one instance of "java.util.WeakHashMap$Entry[]", loaded by "<system class loader>"
Re: Leak suspect report [message #895815 is a reply to message #895768] |
Mon, 16 July 2012 07:48 |
it will if spaces is required and it is well-implemented.
See implementation note from javadoc:
Quote:Implementation note: The value objects in a WeakHashMap are held by ordinary strong references. Thus care should be taken to ensure that value objects do not strongly refer to their own keys, either directly or indirectly, since that will prevent the keys from being discarded. Note that a value object may refer indirectly to its key via the WeakHashMap itself; that is, a value object may strongly refer to some other key object whose associated value object, in turn, strongly refers to the key of the first value object. One way to deal with this is to wrap values themselves within WeakReferences before inserting, as in: m.put(key, new WeakReference(value)), and then unwrapping upon each get.
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Re: Leak suspect report [message #896022 is a reply to message #895815] |
Tue, 17 July 2012 01:00 |
Thanks for the response!
So, the message in the leak suspect report
Is that an indication of being NOT well-implemented and the reason GC will not be able to collect them?
Regards.
Ash.
[Updated on: Tue, 17 July 2012 01:07] Report message to a moderator
FUDForum. Page generated in 0.04639 seconds
