Is latest BPMN2 Modeler compatible with Eclipse 3.8?? [message #895653] |
Sat, 14 July 2012 06:17  |
I am trying to use latest BPMN2 modeler in Eclipse 3.8 but was unable to create or open any Bpmn2 diagram file.
Steps to reproduce:
1.Download Eclipse 3.8
2.Update the eclipse with latest BPMN2 modeler - http://download.eclipse.org/bpmn2-modeler/site/
Note:This will get Graphiti plugins of 0.9 version
3.Create bpmn2 diagram file and press Finish button in the 'BPMN2 Diagram File' wizard
Error dialog with message 'org/eclipse/bpmn2/modeler/ui/wizards/FileService$MyDiagramEditorFactory' gets displayed.
4.Copy any existing bpmn2 diagram file and open it with 'BPMN2 Diagram Editor'
NoClassDefFoundError is thrown
Stack trace:
java.lang.NoClassDefFoundError: org/eclipse/bpmn2/modeler/ui/wizards/FileService$MyDiagramEditorFactory
at org.eclipse.bpmn2.modeler.ui.wizards.FileService.createEmfFileForDiagram(FileService.java:66)
at org.eclipse.bpmn2.modeler.ui.wizards.BPMN2DiagramCreator.createDiagram(BPMN2DiagramCreator.java:60)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.createNewDiagramEditorInput(BPMN2Editor.java:253)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2Editor.init(BPMN2Editor.java:169)
at org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEditorPart.java:237)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2MultiPageEditor.createDesignEditor(BPMN2MultiPageEditor.java:244)
at org.eclipse.bpmn2.modeler.ui.editor.BPMN2MultiPageEditor.createPages(BPMN2MultiPageEditor.java:232)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:315)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2946)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2854)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2846)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2797)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2777)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu.java:338)
at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMenu.java:180)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Did any one face similar kind of issue ?
Is latest BPMN2 modeler compatible with Eclipse 3.8 and Graphiti 0.9??
Best Regards,
Razak
[Updated on: Mon, 16 July 2012 10:45] by Moderator Report message to a moderator
Re: Is latest BPMN2 Modeler compatible with Eclipse 3.8?? [message #895906 is a reply to message #895653] |
Mon, 16 July 2012 13:19   |
Hi Mohammed,
We're still working on migrating the editor from Graphiti 0.8.2 to 0.9.0 because there were some breaking API changes. I'm not sure if there are backward-incompatibilities with other plugins, but you may want to try an install Graphiti 0.8.2 first and then install the editor. Please let me know if that works.
Bob
Re: Is latest BPMN2 Modeler compatible with Eclipse 3.8?? [message #896155 is a reply to message #896048] |
Tue, 17 July 2012 12:33   |
Actually, the code changes are complete (as far as I can tell ) I just need to do some more testing to make sure nothing is broken. This should be available for this week's build (scheduled for this Friday, July 20) or earlier.
I'll post a status update to this forum once I'm satisfied there are no issues with the migration.
Bob
Re: Is latest BPMN2 Modeler compatible with Eclipse 3.8?? [message #896655 is a reply to message #896596] |
Thu, 19 July 2012 09:57   |
Hi all,
I'm using the Eclipse 4.2 (Juno) the modelling Version.
Thanks to your updates for Graphiti 0.9 and BPMN2.0 i can nur start it and partially model.
One problem does occur: I can not edit the the task names, ...
Also the GUI is completely puzzled and you not read at all anymore the models.
Please help to fix this.
Cheers
Torsten
Re: Is latest BPMN2 Modeler compatible with Eclipse 3.8?? [message #897585 is a reply to message #897397] |
Tue, 24 July 2012 15:34   |
Hi all,
I got the latest Update and I can model now BPMN 2.0 Diagrams. Great!
One question: How can I change the name from e.g. a "User Task 1" in my process to a specific user task like "check data record". I can not find a item for changing it. If I do a double click I can only change the item to a "Service Task" or someting else.
I'm using INDIGO (Eclipese 3.7) with Graphiti 0.9 and BPMN2.0 (0.0.1.201207201902)
Cheers
Torsten
Re: Is latest BPMN2 Modeler compatible with Eclipse 3.8?? [message #898607 is a reply to message #897934] |
Thu, 26 July 2012 21:02   |
Hi Robert,
thanks a lot for the image! It explains of who to change it.
I dso net get this property tab activted.
If I do alt+Enter on the Task onject I do get an Error Message
No Property pages for PE....
Is there an other way to activate the property tab?
Sorry It is my first project with eclipse for modelling
Cheers
Torsten
Re: Is latest BPMN2 Modeler compatible with Eclipse 3.8?? [message #898754 is a reply to message #898745] |
Fri, 27 July 2012 12:58   |
Hi Robert,
that was helpful
now I can add the from the Menue (Show View as a fast View) the properties and I can also change them. Great!
By the way an other question: Are there plans to implement a complete roundtrip - so to say generate a GUI, DB, and Java Code to create a complete application based on the process design?
Cheers
Torsten
Re: Is latest BPMN2 Modeler compatible with Eclipse 3.8?? [message #915147 is a reply to message #913015] |
Sun, 16 September 2012 16:19  |
Antonio,
Sorry, I misunderstood what you were trying to do. The BPMN2 wizard category has two entries: BPMN2 Diagram and BPMN2 Model - I now realize that you had selected the second one (Model). This entry actually invokes the model creation wizard from the MDT/BPMN2 metamodel project (here: http://www.eclipse.org/modeling/mdt/?project=bpmn2). This wizard just creates an empty XML document with a <definitions> element and nothing else. Once the wizard is completed, it invokes the default editor associated with bpmn2 content type. Normally, this would be the tree-oriented editor that is generated by EMF for a model but, since the the BPMN2 Modeler is registered as the editor for this content, it is invoked instead. Apparently the BPMN2 Modeler can't handle empty bpmn2 documents
I have created a bugzilla for this, here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=389677
We should have a fix for this by the time the RC1 build becomes available.
Thanks for finding this!
Bob
FUDForum. Page generated in 0.05982 seconds
