Home » Eclipse Projects » WindowBuilder » Test/Preview Different Then Java Application
Test/Preview Different Then Java Application [message #895398] |
Thu, 12 July 2012 17:13 |
J Kelm Messages: 1 Registered: July 2012 |
Very new to WindowsBuilder so here goes:
When I try to create the JPanel and go to preview it, the preview is exactly how I would like it to display. But when I go to run it as a Java Application, it looks completely different with the JLabel and text being placed at the top of the frame. How can I get the 2 to look the same? Here is the sample code being used:
import java.awt.EventQueue;
import javax.swing.JFrame;
import javax.swing.JPanel;
import javax.swing.border.EmptyBorder;
import java.awt.GridBagLayout;
import javax.swing.JLabel;
import java.awt.GridBagConstraints;
import javax.swing.JTextField;
import java.awt.Insets;
import javax.swing.UIManager;
public class HelloWorldFrame extends JFrame {
private JPanel contentPane;
private JTextField textField;
* Launch the application.
try {
UIManager.setLookAndFeel("javax.swing.plaf.metal.MetalLookAndFeel");
} catch (Throwable e) {
e.printStackTrace();
EventQueue.invokeLater(new Runnable() {
public void run() {
try {
HelloWorldFrame frame = new HelloWorldFrame();
frame.setVisible(true);
} catch (Exception e) {
* Create the frame.
public HelloWorldFrame() {
setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
setBounds(100, 100, 800, 800);
contentPane = new JPanel();
contentPane.setBorder(new EmptyBorder(5, 5, 5, 5));
setContentPane(contentPane);
GridBagLayout gbl_contentPane = new GridBagLayout();
gbl_contentPane.columnWidths = new int[]{0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
gbl_contentPane.rowHeights = new int[]{0, 0, 0, 0, 0};
gbl_contentPane.columnWeights = new double[]{0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1.0, Double.MIN_VALUE};
gbl_contentPane.rowWeights = new double[]{0.0, 0.0, 0.0, 0.0, Double.MIN_VALUE};
contentPane.setLayout(gbl_contentPane);
JLabel lblTest = new JLabel("Test:");
GridBagConstraints gbc_lblTest = new GridBagConstraints();
gbc_lblTest.insets = new Insets(0, 0, 0, 5);
gbc_lblTest.anchor = GridBagConstraints.EAST;
gbc_lblTest.gridx = 20;
gbc_lblTest.gridy = 3;
contentPane.add(lblTest, gbc_lblTest);
textField = new JTextField();
GridBagConstraints gbc_textField = new GridBagConstraints();
gbc_textField.fill = GridBagConstraints.HORIZONTAL;
gbc_textField.gridx = 21;
gbc_textField.gridy = 3;
contentPane.add(textField, gbc_textField);
textField.setColumns(10);
Thanks!
Re: Test/Preview Different Then Java Application [message #898587 is a reply to message #895398] |
Thu, 26 July 2012 17:13 |
Konstantin Scheglov Messages: 555 Registered: July 2009 |
This is expected behavior.
WindowBuilder helps you in grid-based layouts, it creates empty, virtual columns and rows.
So, you can quickly start creating UI without adding explicitly columns and rows.
Because they are empty, their size should be zero, but WindowBuilder sets at design time size to some small constant, to allow you drop components there.
But at runtime size will be zero.
Konstantin Scheglov,
Google, Inc.
Current Time: Tue Apr 23 10:38:49 GMT 2024
Powered by FUDForum. Page generated in 0.02428 seconds
