Home » Eclipse Projects » BIRT » How to get chart legend value as an input in parameter of target report
How to get chart legend value as an input in parameter of target report [message #895214] Thu, 12 July 2012 07:30 Go to next message
Sameer Singh is currently offline Sameer SinghFriend
I am hyperlinking a chart with the target report. I want to hyperlink the legend and get the legend value as input in target report parameter. Please suggest some solution.
Re: How to get chart legend value as an input in parameter of target report [message #895395 is a reply to message #895214] Thu, 12 July 2012 17:05 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Take a look at the attached example.
BTW you may want to read over this:
http://birtworld.blogspot.com/2010/05/more-on-chart-interactivity.html
Jason
On 7/12/12 3:30 AM, Sameer Singh wrote:
> Hi
  • Attachment: Archive.zip
    (Size: 6.94KB, Downloaded 157 times)
Re: How to get chart legend value as an input in parameter of target report [message #895507 is a reply to message #895214] Fri, 13 July 2012 10:29 Go to previous message
Thanks Jason It's working Smile
Previous Topic:Return a byte[] array from Java extension function to JavaScript
Next Topic:Re: Setting Persistent Global Variable from DataSet
Current Time: Thu Dec 02 04:26:29 GMT 2021
Powered by FUDForum. Page generated in 0.02121 seconds
