Home » Modeling » TMF (Xtext) » xtext, xtend and source generation
xtext, xtend and source generation [message #895081] Wed, 11 July 2012 15:52 Go to next message
Thomas Schindl is currently offline Thomas SchindlFriend
I've developed my custom DSL and a generator which generates an XML-File
from my DSL.
The problem I'm facing now is that if the users of my plugin are on
different OSes I get whitespace changes because
StringConcatenationBuilder by my template always uses the system
line-breaks (StringConcatenation _builder = new StringConcatenation())
when using multiline strings
Is there someway to configure the line break an xtend-multi line string
should use, e.g. by annotating the method or class?
The original method looks like this:
> class FXGraphTemplate implements IGenerator<FXGraphElement> {
> override generateContent(FXGraphElement element) '''
> LINE1
> LINE2
> LINE3
> @LineBreak("\r\n")
> LINE1
> LINE2
> LINE3
Tom
Re: xtext, xtend and source generation [message #895253 is a reply to message #895081] Thu, 12 July 2012 09:25 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Tom,
there is currently no way to configure that in the code. Did you try to
configure the line delimiter in the preferences of your project (the
project that contains the input files for your generated XML stuff).
There is a class called
'org.eclipse.xtext.generator.LineSeparatorHarmonizer' which in turn uses
a IWhitespaceInformationProvider. The latter reads that preference and
the harmonizer should be configured as the default callback for
generated files.
Sebastian
Am 11.07.12 17:52, schrieb Tom Schindl:
> from my DSL.
>> LINE1
>> LINE2
>> LINE3
>> @LineBreak("\r\n")
>> LINE1
>> LINE2
>> LINE3
> Tom
Re: xtext, xtend and source generation [message #895257 is a reply to message #895081] Thu, 12 July 2012 09:35 Go to previous messageGo to next message
Jan Koehnlein is currently offline Jan KoehnleinFriend
Line separator handling is not yet implemented into the
StringConcatenation itself.
Instead, we usa a post processing approach. If you use an
AbstractFileSystemAccess in the IGenerator, there is an
IFilePostProcessor injected. The default LineSeparatorHarmonizer
replaces all newlines with what is configered with as the
> from my DSL.
>> LINE1
>> LINE2
>> LINE3
>> @LineBreak("\r\n")
>> LINE1
>> LINE2
>> LINE3
> Tom
Get professional support from the Xtext committers at www.typefox.io
Re: xtext, xtend and source generation [message #895267 is a reply to message #895253] Thu, 12 July 2012 10:13 Go to previous message
Works like a charme - I've replaced the default one with my custom which
forces the windows "\r\n".
Tom
Am 12.07.12 11:25, schrieb Sebastian Zarnekow:
> Hi Tom,
> generated files.
> Regards,
> Sebastian
Previous Topic:OCL: Iterate over code lines
Next Topic:Cross reference is being activated without an import, why ?
Current Time: Fri Apr 10 01:14:29 GMT 2020
Powered by FUDForum. Page generated in 0.01838 seconds
