Home » Modeling » TMF (Xtext) » Cross reference is being activated without an import, why ?
Cross reference is being activated without an import, why ? [message #895077] Wed, 11 July 2012 15:42 Go to next message
Cristiano Gavião is currently offline Cristiano GaviãoFriend
I've create a little default model to play with cross references, without change mwe2.
But I'm getting a strange behavior. The cross references is being activated without the use of the import rule !
After run, I've create a project, one package and two files. In the second file, without an import statement, I could reference another organization element from the first file:
Organization:{
	code ferrari
	name "Ferrari"
Organization:{
	code C4Biz
	name "Long name"
	Partnerships:{
		Partnership:{
			[b]partner ferrari[/b]
could someone explain me why ?
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Organization:
	//(imports+=ImportNamespace*)?
	'Organization:'
 	'code' name=ID
 	'name' longname=STRING
	('description' description=STRING)?
	('Partnerships:' '{' partnerships+=Partnership* '}')?
//ImportNamespace:
//	'Import' importedNamespace=FqnWithWildCard
Partnership:
	'Partnership:'
	'partner' company=[Organization|Fqn]
	('agreement' agreement=STRING)?
FqnWithWildCard:
	Fqn ('.' '*')?;
Fqn:
  ValidID (=>'.' ValidID)*;
ValidID:
	ID;
thanks,
Cristiano
Re: Cross reference is being activated without an import, why ? [message #895079 is a reply to message #895077] Wed, 11 July 2012 15:45 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi imports is only for shortening names - not for general visibility
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
Re: Cross reference is being activated without an import, why ? [message #895100 is a reply to message #895079] Wed, 11 July 2012 16:59 Go to previous messageGo to next message
Hi Christian,
don't know if I understood what you have write... :/
It means that if I had lot of files in the same project and in referenced manifest, all of them will be loaded same time?
About the shortening name, if both files are in the package "companies", wouldn't the content assist put the qualified name instead the single name?
'Cause I'm using this in grammar: 'partner' company=[Organization|Fqn]
I'm getting this: partner ferrari
shouldn't be partner companies.ferrari ?
thanks,
Cristiano
Re: Cross reference is being activated without an import, why ? [message #895106 is a reply to message #895100] Wed, 11 July 2012 17:12 Go to previous messageGo to next message
i am saying:
xtext uses the qualified names of things (here Organization) to store them in the index.
the qualified name is by default parentFQN.elementname
since the org has no parent the orgs name is its name => ferrari
(you do not have any packages in your dsl - folder structure does not count (by default))
=> orgs are visible by their simple name and you need no import nor using a fqn to reference it
~Christian
Re: Cross reference is being activated without an import, why ? [message #895114 is a reply to message #895106] Wed, 11 July 2012 17:54 Go to previous messageGo to next message
Hummm, cool. I think I start to understand this subject. Smile
Two more doubts:
- In our company here, normally we have some rules to name attributes: id (auto generated), code (meaningful with no space), name (meaningful with space).
I want to use qualified in our DSL, so name must not have spaces.
Is there a way to custom xtext so it work with 'code' instead 'name' ?
- In the example that I showed, one organization can't be partner of itself. Where should I custom to avoid the self reference ?
thanks a lot,
Cristiano
Re: Cross reference is being activated without an import, why ? [message #895115 is a reply to message #895114] Wed, 11 July 2012 17:59 Go to previous messageGo to next message
Yes have a look at iqualifiednameprovider
Re: Cross reference is being activated without an import, why ? [message #895313 is a reply to message #895115] Thu, 12 July 2012 12:35 Go to previous message
Ok Christian,
thanks a lot for the tips.
For those that have the same doubts than I there some good article about iqualifiednameproviders here:
http://christiandietrich.wordpress.com/2011/07/16/iqualifiednameproviders-in-xtext-2-0/
and about Scopes here:
http://blogs.itemis.de/stundzig/archives/773
Previous Topic:xtext, xtend and source generation
Next Topic:How to disable auto activation of content assist
Current Time: Sat Aug 08 01:24:58 GMT 2020
Powered by FUDForum. Page generated in 0.17342 seconds
