Re: [CDO] Exception on pre-built binary package [message #895059 is a reply to message #894957] |
Wed, 11 July 2012 14:53 |
Am 11.07.2012 10:55, schrieb Federico Tomassetti:
> By the way the exception is thrown again and again every few seconds.
Hmm, that's kind of odd, but in no way hindering evaluation. If, on the client-side, you close the CDO Administration
view it should go away (fix1). You can also fix it by manually deploying the org.eclipse.emf.cdo.server.admin bundle to
the server (fix2).
The reason for this behaviour is that the new CDO Administration view periodically tries to establish a cdo-admin
protocol connection to all configured servers and list their repositories. This bug describes the new CDOAdmin API:
381472: Design a repository administration API
https://bugs.eclipse.org/bugs/show_bug.cgi?id=381472
These types form the client-side API:
/org.eclipse.emf.cdo.admin/src/org/eclipse/emf/cdo/admin/CDOAdminClient.java
/org.eclipse.emf.cdo.admin/src/org/eclipse/emf/cdo/admin/CDOAdminClientManager.java
/org.eclipse.emf.cdo.admin/src/org/eclipse/emf/cdo/admin/CDOAdminClientRepository.java
/org.eclipse.emf.cdo.admin/src/org/eclipse/emf/cdo/admin/CDOAdminClientUtil.java
Can you please submit a bugzilla so that I can fix the your current problem in the next maintenance build (fix1)?
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
Re: [CDO] Exception on pre-built binary package [message #981340 is a reply to message #895060] |
Mon, 12 November 2012 10:43 |
Etienne ALLOGO Messages: 4 Registered: November 2012 |
I have the following trace when I call CdoAdmin.createRepository :
net4j-Thread-5 [org.eclipse.internal.net4j.buffer.BufferPool] Obtained Buffer@204[INITIAL]
net4j-Thread-5 [org.eclipse.net4j.signal.SignalProtocol] Put signal id 4
[WARN] A problem occured while notifying client SignalProtocol[cdo-admin]
at org.eclipse.emf.cdo.server.internal.admin.CDOAdminServerRepository.write(CDOAdminServerRepository.java:197)
at org.eclipse.emf.cdo.server.internal.admin.protocol.RepositoryAddedRequest.requesting(RepositoryAddedRequest.java:35)
at org.eclipse.net4j.signal.Request.doExtendedOutput(Request.java:67)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:298)
at org.eclipse.net4j.signal.Request.doExecute(Request.java:59)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:440)
at org.eclipse.net4j.signal.Request.sendAsync(Request.java:53)
at org.eclipse.emf.cdo.server.internal.admin.protocol.CDOAdminServerProtocol.sendRepositoryAdded(CDOAdminServerProtocol.java:51)
at org.eclipse.emf.cdo.server.internal.admin.CDOAdminServer.repositoryAdded(CDOAdminServer.java:164)
at org.eclipse.emf.cdo.server.internal.admin.CDOAdminServer$1.onAdded(CDOAdminServer.java:52)
at org.eclipse.net4j.util.container.ContainerEventAdapter$1.added(ContainerEventAdapter.java:50)
at org.eclipse.net4j.util.container.ContainerEvent.accept(ContainerEvent.java:113)
at org.eclipse.net4j.util.container.ContainerEventAdapter.notifyContainerEvent(ContainerEventAdapter.java:46)
at org.eclipse.net4j.util.container.ContainerEventAdapter.notifyEvent(ContainerEventAdapter.java:35)
at org.eclipse.net4j.util.event.Notifier.fireEventSafe(Notifier.java:146)
at org.eclipse.net4j.util.event.Notifier.fireEvent(Notifier.java:110)
at org.eclipse.net4j.util.event.Notifier.fireEvent(Notifier.java:86)
at org.eclipse.net4j.util.container.ManagedContainer.fireEvent(ManagedContainer.java:478)
at org.eclipse.net4j.util.container.ManagedContainer.putElement(ManagedContainer.java:361)
at org.eclipse.net4j.util.container.ManagedContainer.putElement(ManagedContainer.java:337)
at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:207)
at org.eclipse.emf.cdo.server.internal.admin.CDOAdminServer.doCreateRepository(CDOAdminServer.java:110)
at org.eclipse.emf.cdo.spi.common.admin.AbstractCDOAdmin.createRepository(AbstractCDOAdmin.java:105)
at org.eclipse.emf.cdo.server.internal.admin.protocol.CreateRepositoryIndication.responding(CreateRepositoryIndication.java:54)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:98)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:67)
at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
My client code is :
package ........model.tests;
import java.io.IOException;
import java.util.HashMap;
import java.util.Map;
import junit.framework.Assert;
import org.eclipse.emf.cdo.admin.CDOAdminClient;
import org.eclipse.emf.cdo.admin.CDOAdminClientUtil;
import org.eclipse.emf.cdo.common.admin.CDOAdmin;
import org.eclipse.emf.cdo.common.admin.CDOAdminRepository;
import org.eclipse.emf.cdo.net4j.CDONet4jSession;
import org.eclipse.emf.cdo.net4j.CDONet4jSessionConfiguration;
import org.eclipse.emf.cdo.net4j.CDONet4jUtil;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.ecore.EAttribute;
import org.eclipse.net4j.Net4jUtil;
import org.eclipse.net4j.connector.IConnector;
import org.eclipse.net4j.tcp.TCPUtil;
import org.eclipse.net4j.util.container.IPluginContainer;
import org.eclipse.net4j.util.io.IOUtil;
import org.eclipse.net4j.util.lifecycle.ILifecycle;
import org.eclipse.net4j.util.lifecycle.LifecycleEventAdapter;
import org.junit.BeforeClass;
import org.junit.Test;
public class TestCdoClient {
private static IConnector connector;
public static final long DEFAULT_TIMEOUT = 500;
private static final String ADMIN_HANDLER_TYPE = ConnectionPackage.eNS_PREFIX;
@BeforeClass
public static void init() {
// The following lines are not needed if the extension
// registry (OSGi/Equinox) is running
Net4jUtil.prepareContainer(IPluginContainer.INSTANCE);
TCPUtil.prepareContainer(IPluginContainer.INSTANCE);
connector = (IConnector) IPluginContainer.INSTANCE.getElement( //
"org.eclipse.net4j.connectors", // Product group
"tcp", // Type
"localhost:2036");
@Test
public void test() throws IOException, InterruptedException {
CDOAdmin admin = openAdmin(null);
try {
int size = admin.getRepositories().length;
.. repo = ...Factory.eINSTANCE
.create...Repository();
repo.setDatabaseHostName("localhost");
final String value = "cdoTestClientRepo"
+ System.currentTimeMillis();
repo.setName(value);
Map<String, Object> propperties = new HashMap<String, Object>();
EList<EAttribute> attributes = repo.eClass().getEAttributes();
for (EAttribute eAttribute : attributes) {
propperties.put(eAttribute.getName(), repo.eGet(eAttribute));
CDOAdminRepository repo2 = null;
try {
// FIXME BUG CDO
repo2 = admin.createRepository(value, ADMIN_HANDLER_TYPE,
propperties);
} catch (Exception e) {
e.printStackTrace();
// FIXME BUG CDO - Always occurred
} finally {
disposeAdmin(admin);
CDOAdminRepository[] repos = admin.getRepositories();
for (CDOAdminRepository cdoAdminRepository : repos) {
if (cdoAdminRepository.getName().equals(repo.getName())) {
repo2 = cdoAdminRepository;
Assert.assertNotNull(repo2);
Assert.assertEquals(value, repo2.getName());
Assert.assertEquals(size + 1, admin.getRepositories().length);
repo2.delete(ADMIN_HANDLER_TYPE);
Assert.assertEquals(null, admin.getRepository(value));
Assert.assertEquals(size, admin.getRepositories().length);
} finally {
cleanup(admin);
private CDOAdmin openAdmin(Object object) throws InterruptedException {
String url = connector.getURL();
final CDOAdminClient admin = CDOAdminClientUtil.openAdmin(url,
DEFAULT_TIMEOUT);
long timeout = System.currentTimeMillis() + DEFAULT_TIMEOUT + 10;
while (System.currentTimeMillis() < timeout && !admin.isConnected()) {
Thread.sleep(10);
return admin;
private void cleanup(CDOAdmin admin) {
connector.close();
private void disposeAdmin(CDOAdmin admin) {
IOUtil.closeSilent(admin);
I have to dispose CDOAdmin and reopen it to conturn this excepion.
I've always a Timeout excetion on client site that I catch, but it will be difficult to maintain an efficient code in my UI application.
FUDForum. Page generated in 0.04013 seconds
