Home » Eclipse Projects » BIRT » Generate excel reports
Generate excel reports [message #894825] Tue, 10 July 2012 16:39 Go to next message
Neil Wang is currently offline Neil WangFriend
When generating Excel from BIRT reporting, only a single work sheet is generated. Is there a way to generate multiple work sheets?
regards,
Neil
Re: Generate excel reports [message #894846 is a reply to message #894825] Tue, 10 July 2012 18:17 Go to previous message
Michael Williams is currently offline Michael WilliamsFriend
I'm pretty sure the standard emitter still doesn't allow for multiple sheets. Depending on your version, there are a few options available that allow for multiple sheets based on page breaking. You might take a look at the emitters linked in the following thread.
http://www.eclipse.org/forums/index.php/t/367145/
Michael
Developer Evangelist, Silanis
Previous Topic:Incorrect pagination for a report with chart and tabular data.
Next Topic:Addition of two number fields Example(Java script through expression builder)
Current Time: Sat Nov 27 15:38:01 GMT 2021
Powered by FUDForum. Page generated in 0.02166 seconds
