Error loading a resource file [message #894761] |
Tue, 10 July 2012 12:32 |
Stefan Mertins Messages: 11 Registered: March 2012 |
I work on a plugin JUnit Test (for a eclipse rcp). I need to load an external model file. To do so, I used example code form www.vogella.com/articles/EclipseEMFPersistence/article.html that shows how to load a file.
How ever, I always get an "org.eclipse.core.internal.resources.ResourceException: Resource '/home/sme/PSManager.ifg' does not exist." Exception thrown in PlatformResourceURIHandlerImpl.
My first atempts looked like this:
Resource.Factory.Registry reg = Resource.Factory.Registry.INSTANCE;
Map<String, Object> m = reg.getExtensionToFactoryMap();
m.put("ifg", new XMIResourceFactoryImpl());
// Obtain a new resource set
ResourceSet resSet = new ResourceSetImpl();
//load the Resource
//URI ifgURI1 = URI.createURI(this.getClass().getResource(IFG_FILE).toURI().getPath());
URI ifgURI2 = URI.createURI(new File(IFG_FILE_ABSOLUT_PATH).getAbsolutePath());
Resource ifgResource = resSet.getResource(ifgURI2, true);
After checking the files and permissions double I moved on to check the Internet for solutions. I found a post (www.eclipsezone.com/eclipse/forums/t116946.rhtml) stating its an Linux problem (I also use a linux system) and can be fixed by setting up a project in the workspace for the file.
IWorkspace ws = ResourcesPlugin.getWorkspace();
IProject project = ws.getRoot().getProject("res");
if (!project.exists())
project.create(null);
if (!project.isOpen())
project.open(null);
IPath location = new Path(IFG_FILE_ABSOLUT_PATH);
IFile iFile = project.getFile(location.lastSegment());
iFile.createLink(location, IResource.NONE, null);
But still the error remains. After a couple of other tries I decided to copy the portion of the Class PlatformResourceURIHandlerImpl that causes the crash into my code, to be able to debug better. It's the Method public static InputStream createPlatformResourceInputStream(String platformResourcePath, Map<?, ?> options) throws IOException
Expecially the Part where the InputStream is created:
try{
if (!file.isSynchronized(IResource.DEPTH_ONE)){
file.refreshLocal(IResource.DEPTH_ONE, null);
InputStream result = file.getContents();
catch (Exception e){
e.printStackTrace();
Guess what? The code runs just fine in my Class, but crashs in PlatformResourceURIHandlerImpl.
Anyone has a idea what I do wrong here or what I can do better?
Greetings
Stefan
Stack Trace:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.core.internal.resources.ResourceException: Resource '/home/sme/git/probate/org.infai.probate.testplan.export.test/res/PSManager.ifg' does not exist.
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
at org.infai.probate.testplan.export.test.TestplanGeneratorTest.loadTestModel(TestplanGeneratorTest.java:101)
at org.infai.probate.testplan.export.test.TestplanGeneratorTest.createTestplanTest(TestplanGeneratorTest.java:42)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.runners.BlockJUnit4ClassRunner.runNotIgnored(BlockJUnit4ClassRunner.java:79)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:71)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:49)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:52)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:191)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:42)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:184)
at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.main(RemotePluginTestRunner.java:62)
at org.eclipse.pde.internal.junit.runtime.PlatformUITestHarness$1.run(PlatformUITestHarness.java:47)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3563)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3212)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.pde.internal.junit.runtime.NonUIThreadTestApplication.runApp(NonUIThreadTestApplication.java:54)
at org.eclipse.pde.internal.junit.runtime.UITestApplication.runApp(UITestApplication.java:41)
at org.eclipse.pde.internal.junit.runtime.NonUIThreadTestApplication.start(NonUIThreadTestApplication.java:48)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Re: Error loading a resource file [message #894797 is a reply to message #894761] |
Tue, 10 July 2012 14:40 |
Ed Merks Messages: 33140 Registered: July 2009 |
Stefan,
Comments below.
On 10/07/2012 2:32 PM, Stefan Mertins wrote:
> Hello,
> how to load a file.
You can only use platform:/resource URIs if you have a workspace. If
you're dealing with files, you'll want a file: URI.
> //load the Resource
> //URI ifgURI1 =
You'll want createFileURI; a file system path is not a URI...
> project.open(null);
> ?> options) throws IOException Expecially the Part where the
> try{
> Greetings
> Stefan
> Stack Trace:
> does not exist.
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> at
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
Ed Merks
FUDForum. Page generated in 0.02147 seconds
