Home » Eclipse Projects » Eclipse Platform » Debugging Debug code
Debugging Debug code [message #894713] Tue, 10 July 2012 08:59 Go to next message
saurav sarkar is currently offline saurav sarkarFriend
Hi All,
I want to debug the debug framework code.
Since the actual application code will be in the runtime workbench and the debug breakpoints will hit in the development IDE. I am not able to find out about how can i debug the code where the execution is happening in the debvelopment IDE.
Will remote debugging help me in this context ?
cheers,
Saurav
Re: Debugging Debug code [message #894740 is a reply to message #894713] Tue, 10 July 2012 10:26 Go to previous messageGo to next message
Saurav,
It sounds like you need to launch a runtime bench under debug control
and from that launch the application under debug control. Then when the
application hits a breakpoint, and the debug framework handles that,
your main IDE will hit the breakpoints you've put in the debug framework.
On 10/07/2012 10:59 AM, saurav sarkar wrote:
> Hi All,
> cheers,
> Saurav
Ed Merks
Re: Debugging Debug code [message #894915 is a reply to message #894740] Wed, 11 July 2012 05:44 Go to previous message
Hi Ed,
Thanks for the reply.
Silly me i tried that earlier but because of the same workspace configuration i could not spawn off a separate workbench instance
and i thought it could not be done Smile.
Now i could change the workspace and do the debug as the way you mentioned.
cheers,
Saurav
Previous Topic:Outline View (Tree Update of Folded and Unfolded Nodes)
Next Topic:Editor Visibility
Current Time: Tue Apr 16 22:17:18 GMT 2024
Powered by FUDForum. Page generated in 1.00544 seconds
