Home » Archived » AMW » Problems - AMW and XML Schemas
Problems - AMW and XML Schemas [message #894379] Sun, 08 July 2012 23:55 Go to next message
Iuri Teixeira is currently offline Iuri TeixeiraFriend
sorry my bad english, I'm several days trying to solve a problem with AMW, and if possible I would like a little help.
The versions of the technologies that I am using are below:
- Windows 7 64
1 - Eclipse Modeling Tools: Version: Indigo Service Release 2; Build id: 20120216-1857
 1.1 Eclipse Plataform: 3.7.2
 1.2 MoDisco SDK (incubation): 0.9.2
 1.3 EGF SDK: 1.0.0
 1.4 ATL SDK: 3.2.1
 1.4 AMW: "Manually installed". Development build for ALT 3.x. (http://www.eclipse.org/downloads/download.php?file=/modeling/gmt/amw/binaries/AMW-stable/mwplugins-stable.zip). Obs.: Plugins included in the directory "dropins" of the Eclipse:
  ../eclipse/dropings/org.eclipse.gmt.weaver.extension.base_2.0.0.jar
  ../eclipse/dropings/org.eclipse.gmt.weaver.matchextensions_1.0.0.jar
  ../eclipse/dropings/org.eclipse.gmt.weaver.qatl_1.0.0.jar
  ../eclipse/dropings/org.eclipse.gmt.weaver.transformation.extension_1.0.0.jar
  ../eclipse/dropings/org.eclipse.gmt.weaver.transformation_1.0.0.jar
  ../eclipse/dropings/org.eclipse.gmt.weaver_2.0.0.jar
 1.5 XSD to Ecore (XSD model Importer): 2.6.0
2 Weaver Metamodel: mmw_annotation.ecore. Extracted from mmw_annotation.km3 through the Eclipse Europa with the ATL2
 2.1 Weaver Menu > Save weaving Metamodel in ecore format.
I'm having trouble to validate a AMW model, which results in errors after the AMW wizard. I will be brief in my goal: Perform transformations (ATL) from a model A to a model B, using a third model C. This model C assist the transformations with informations of the model A. For simplify my problem,
I will use simples models in anexe: Author.xsd, Author.ecore, My.author and mmw_annotation.ecore.
My model A (Author.xml) is defined in XML Schemas (Author.xsd).
So, I import this XML Schema to Ecore metamodel (Author.xsd to Author.ecore) using the Eclipse for a new project EMF.
In simple tests, without using XSM Schemas, I have no problem in creating a model AMW. For example:
Wizard Weaving Model > Weaving metamodel = "mmw_annotation.ecore" > File Name = "test1.amw" > Enter model and metamodel information: model = TestM.testmm, metamodel = "TestMM.ecore" > "Success!"
My problem starts when I use Ecore metamodels (Author.ecore) derived from XML Schemas (Author.xsd) as imput for the AMW model (test2.amw). For example:
Wizard Weaving Model > Weaving metamodel = "mmw_annotation.ecore" > File Name = "test2.amw" > Enter model and metamodel information: model = My.author, metamodel = "Author.ecore" > "Fail!"
Soon after, errors occur that can not understand after a empty error window.
Does anyone can have any idea what might be happening?
Sorry if I forgot some important details.
Message:Unable to create editor ID org.eclipse.gmt.weaver.globalWeaverEditorID: assertion failed:
Exception Stack Trace:
org.eclipse.core.runtime.AssertionFailedException: assertion failed:
	at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
	at org.eclipse.core.runtime.Assert.isTrue(Assert.java:96)
	at org.eclipse.ui.part.MultiPageEditorPart.setActivePage(MultiPageEditorPart.java:1065)
	at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:352)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
	at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
	at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
	at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
	at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
	at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
	at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
	at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
	at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
	at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
	at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
	at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
	at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
	at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:747)
	at org.eclipse.gmt.weaver.wizards.WeaverWizard$2.run(WeaverWizard.java:336)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:173)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:388)
	at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1029)
	at org.eclipse.gmt.weaver.wizards.WeaverWizard.performFinish(WeaverWizard.java:172)
	at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
	at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
	at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:257)
	at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:277)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
	at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
	at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
 Message:
An unexpected exception was thrown:
	at org.eclipse.gmt.weaver.editors.GlobalWeaverEditor.dispose(GlobalWeaverEditor.java:469)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:705)
Re: Problems - AMW and XML Schemas [message #895105 is a reply to message #894379] Wed, 11 July 2012 17:10 Go to previous messageGo to next message
Marcos Didonet Del Fabro is currently offline Marcos Didonet Del FabroFriend
its probably related to the types of your elements in the authors.ecore metamodel.
eType="ecore:EClass http://www.eclipse.org/emf/2002/Ecore#//EStringToStringMapEntry"
The weaver editor does not handle this kind of data types.
Marcos.
Re: Problems - AMW and XML Schemas [message #895206 is a reply to message #895105] Thu, 12 July 2012 05:32 Go to previous message
I also tried to use the Eclipse Helios (AMW + ATL3) but had no success, the same errors occur. I also tried to use Eclipse 3.3.0 (AMW + ATL2), but different error occurs, however, my ATL transformations do not work with ATL2.
Does anyone have any suggestions for the AMW accept models informations from Ecore metamodels generated from XSD?
Iuri.
Previous Topic:Weaving Metamodel Creation for AMW 2.0
Next Topic:Extract Model Element Type with getReferredElement
Current Time: Wed Aug 12 01:39:18 GMT 2020
Powered by FUDForum. Page generated in 0.01834 seconds
