Home » Eclipse Projects » Remote Application Platform (RAP) » Super Tooltip(A pop up box that shows more content than a regular tooltip item)
Super Tooltip [message #894122] Fri, 06 July 2012 18:06 Go to next message
Ronald So is currently offline Ronald SoFriend
Is it possible for RAP to show a super tooltip like the following image?
http://www.useit.com/alertbox/super-tooltip.png
It will be very nice if this is doable in RAP as most modern Web application utilizes this component for just-in-time-help.
Thanks!
Ronald
Re: Super Tooltip [message #894732 is a reply to message #894122] Tue, 10 July 2012 09:56 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi Roland,
you could try the org.eclipse.swt.widgets.ToolTip widget. Currently, the
ToolTip widget does not support markup, but if you need it please open
an enhancement request.
Best,
Ivan
On 7/6/2012 9:06 PM, Ronald So wrote:
> Thanks!
> Ronald
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Super Tooltip [message #894733 is a reply to message #894122] Tue, 10 July 2012 10:00 Go to previous messageGo to next message
Tim Buschtoens is currently offline Tim BuschtoensFriend
Hi!
Well, there is the ToolTip widget in RAP, which mostly looks like this.
You can use RAP theming to change details like background and shadow.
However, it's limited regarding its content (plain text and one image
only), and it also doesn't support the "BALLOON" flag that gives it the
"tail"/pointer. If you don't require the pointer or widgets inside the
ToolTip, thats the one to use. If you want widgets inside, a shell could
be styled/themed like a ToolTip.
If you want that ballon look, its more complicated. We considered many
times to implement such pointers for certain widgets, but it proves to
be complicated for several reasons. Having said that, here is what could do:
1) Open an enhancement bug on bugzilla and wait for us to do it. The
problem is obviously that neither of us knows when that would happen.
However, just supporting the BALLOON flag for ToolTip should be
manageable work. I'm pretty sure it would be in Kepler.
2) I think it might be possible to hack the shell to achieve the effect.
I could give you some pointer, but remember it would be a hack, and I'm
not sure it would work out.
Greetings,
Tim
Am 06.07.2012 20:06, schrieb Ronald So:
> Thanks!
> Ronald
Tim Buschtöns
Re: Super Tooltip [message #895605 is a reply to message #894733] Fri, 13 July 2012 18:30 Go to previous messageGo to next message
Thanks Tim. I am sure the shell approach will work just fine but it also requires quite a bit of coding to get the job done. While we are using RAP to build web applications, features like a super tool tip is highly desired that it works out of the box. May be I should log an enhancement request?
Re: Super Tooltip [message #895832 is a reply to message #895605] Mon, 16 July 2012 08:49 Go to previous message
Hi.
Am 13.07.2012 20:30, schrieb Ronald So:
Sure, go ahead. Please be as precise as possible on what you need
regarding visuals, features and API.
Greetings,
Tim
Tim Buschtöns
Previous Topic:Integration of a RAP application and Spring managed eclipse plugin
Next Topic:Applications in RAP
Current Time: Sun Dec 05 00:02:13 GMT 2021
Powered by FUDForum. Page generated in 0.01598 seconds
