Re: Two RAP application in the SAME Virgo kernel [message #894133 is a reply to message #894103] |
Fri, 06 July 2012 20:32 |
Florian Waibel Messages: 166 Registered: June 2010 |
Yes putting the VM argument to org.eclipse.virgo.kernel.launch.properties seems the better place.
It is possible to run multiple HttpServices on different ports but I personally think it would be easier to register different EntryPoints at different servlet paths on the same HttpService than hosting multiple HttpServices with one application each.
That's the same result as you would get with with one standalone servlet container and two war artifacts.
Regarding the WAB bundles: Maybe you can have a look at GitHUB github.com/fappel/RWT_SPRING
Hope this helps,
Florian
Here is a discussion about multiple HttpServices in the context of RAP. https://bugs.eclipse.org/bugs/show_bug.cgi?id=241210
[Updated on: Fri, 06 July 2012 20:34] Report message to a moderator
Re: Two RAP application in the SAME Virgo kernel [message #898771 is a reply to message #894667] |
Fri, 27 July 2012 13:58 |
I want to thank you for the tutorial on RWT/Virgo, I followed it and easily succeed .
For information, it also works with Virgo 3.5.0.RELEASE (but you have to put the http-service port on configuration/config.ini instead of the missing old launch config).
I'm a RAP beginner, so I wanted to ask you some questions:
* I wanted to know if it's also possible to integrate RAP ui & JFace (in Virgo) as easily as RWT?
* Also is server push (RAP way) is supported?
* How can I do to mimic extensions point (located in plugins.xml with equinox) with Virgo? I think this has to be done with an OSGI services (for example with spring-dm) but I'm not sure.
* Finally, what's the best way to make a dynamic RAP application (as you can do with snaps), is it possible without a 'super app' depending on all the RAP parts?
My best, Charlie
Re: Two RAP application in the SAME Virgo kernel [message #909260 is a reply to message #899255] |
Thu, 06 September 2012 20:29 |
I'm sorry Florian, I had'nt saw your answer.
Thank you for your answers, you're a man .
I tried to integrate JFace Databinding with Virgo (with osgi http services), but it complains about null realms. I think i've to deal with clustered web.xml conf :S.
Concerning the other points, (jface without db, asynccall, dynamic app...), I will test this once I will resolve the issue for sure
My best,
Charlie
FUDForum. Page generated in 0.02082 seconds
