Home » Eclipse Projects » Remote Application Platform (RAP) » about RWT.FIXED_COLUMNS
about RWT.FIXED_COLUMNS [message #893626] Thu, 05 July 2012 01:57 Go to next message
ocean xue is currently offline ocean xueFriend
code Snippet1: treeVirtual.setData(RWT.FIXED_COLUMNS, 5);
code Snippet2:
final TreeEditor editor = new TreeEditor(treeVirtual);
final Button button = new Button(treeVirtual, SWT.NONE);
button.setText("test");
editor.grabHorizontal = true;
editor.setEditor(button, citem, 6);
the 6 TreeColumn change TreeEditor drag the scroll bar control does not hide?
Thanks a lot
Re: about RWT.FIXED_COLUMNS [message #893669 is a reply to message #893626] Thu, 05 July 2012 08:09 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
I didn't get what is the issue. Please provide the complete self-running
snippet that demonstrate the problem.
Best,
Ivan
> code Snippet2:
> not hide?
> Thanks a lot
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: about RWT.FIXED_COLUMNS [message #893916 is a reply to message #893669] Fri, 06 July 2012 03:03 Go to previous messageGo to next message
Snippet 1
Tree treeVirtual = new Tree(compActual, SWT.BORDER | SWT.FULL_SELECTION);
treeVirtual.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true,
true, 1, 1));
treeVirtual.setLinesVisible(true);
treeVirtual.setHeaderVisible(true);
Snippet 2
private TreeItem createItem(TreeItem parentItem, String str, String str1,
String str2, String str3, String str4, String str5,
String str6,String str7, String str8) {
TreeItem citem = new TreeItem(parentItem, SWT.NONE);
citem.setText(str);
citem.setText(1, str1);
citem.setText(2, str2);
citem.setText(3, str3);
citem.setText(4, str4);
citem.setText(5, str5);
citem.setText(7, str7);
citem.setText(8, str8);
return citem;
drag the scroll bar button does not hide?
  • Attachment: init.png
    (Size: 11.96KB, Downloaded 174 times)
  • Attachment: scroll.png
    (Size: 12.22KB, Downloaded 170 times)
[Updated on: Fri, 06 July 2012 03:03]
Report message to a moderator
Re: about RWT.FIXED_COLUMNS [message #893924 is a reply to message #893916] Fri, 06 July 2012 05:55 Go to previous messageGo to next message
you mean that the cell editor (button) is not hidden behind the fixed
columns when scrolling right? If this is the problem - this is done by
design. Try to hide the editors (buttons) yourself by listening for the
horizontal scrollbar selection event. If you think that this is not
correct please file an enhancement request.
Best,
Ivan
On 7/6/2012 6:03 AM, ocean Mising name wrote:
> Snippet 1
> true, 1, 1));
> Snippet 2
> citem.setText(str);
> button.setText(str15);
> return citem;
Ivan Furnadjiev
Re: about RWT.FIXED_COLUMNS [message #893938 is a reply to message #893924] Fri, 06 July 2012 06:54 Go to previous message
Yes, can not hide.
How to achieve? sample code?
Thanks a lot.
Previous Topic:Needes Plugins/Features for a WAR file
Next Topic:Integration of a RAP application and Spring managed eclipse plugin
Current Time: Sun Dec 05 01:47:50 GMT 2021
Powered by FUDForum. Page generated in 0.02738 seconds
