Java generation error when calling service. [message #893555] |
Wed, 04 July 2012 10:33  |
I'm experimenting with EGL and making calls to IBM i commands.
I would like to separate the actual implementation of the EGL calls to the IBM i commands from any client programs.
I've created a project called EGLCommon which contains 2 packages; libraries and services.
The libraries package contains an EGL library which is made up of one function that calls QCMDEXC:
package libraries;
library iLibrary
function QCMDEXC(input string in, length decimal(15,5) in)
@Resource{ uri = "binding:IBMi" },
@IBMiProgram {
programName = "QCMDEXC",
libraryName = "/QSYS.LIB",
parameterAnnotations = [
@StructText {length = 80},
@StructPackedDecimal {}
end
end
The services package contains an EGL service which is a function called runCmd which calls iLibrary.QCMDEXC:
package services;
import libraries.*;
service iService
function runCmd(command string in)
iLibrary.QCMDEXC(command, characterLen(clip(command)));
end
end
The deployment descriptor in this project contains an IBM i binding pointing to our i5.
I've then created another project called EGLClient. This contains a program called TestClient which calls runCmd. The EGLCommon project is in the EGL build path and I've created a REST binding to iService.
The code for TestClient is:
package client;
import services.*;
program TestClient
function main()
iServicesSvc IHttp?{@Resource {uri="binding:iService"}};
command string = "SNDMSG MSG(HELLO) TOUSR(TOMYUSR)";
call iService.runCmd(command) using iServicesSvc;
end
end
The EGLCommon project has generated OK but I'm getting java generation errors on the EGLClient project. The errors I get are:
com.ibm.javart cannot be resolved to a type
ezeProgram cannot be resolved
ezeProgram cannot be resolved to a variable
iService cannot be resolved to a variable
Type mismatch: cannot convert from String to JavartSerializable
So, is it not possible to have this level of separation, or am I missing something from the EGLClient project?
I'm using EDT milestone 3 (Version: 0.8.1.v201206280959-1Ds7rFmiVCcYWyaY3NTPd8hSh)
Steve
Re: Java generation error when calling service. [message #893871 is a reply to message #893833] |
Thu, 05 July 2012 14:44  |
Hi Steve,
What you said will work, however, I would make 1 change to make it more modular. I would put the IBMi resource bindings in the DD, in the project that contains the library. Then the bindings only reside in 1 place and as you said you can create multiple client projects. This way there is no need for the client to have any IBMi information.
regards,
Joe
FUDForum. Page generated in 0.03977 seconds
