Home » Modeling » Graphiti » Set Text to the right position
Set Text to the right position [message #893507] Wed, 04 July 2012 11:40 Go to next message
Patrick Rütz is currently offline Patrick RützFriend
Hi I have a little problem. I have made a customfeature. I have a Pictogrammelement which i made smaller bei setting the height and widthvalue, but if i do this, the text isn´t shown anymore. So I want to set the text new. But i don´t know how i can do this, especially how I can get the text element.
Thanks a lot
Re: Set Text to the right position [message #893707 is a reply to message #893507] Thu, 05 July 2012 10:23 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
To help more concretely, I would need some more information...
I would assume that the PictogramElement is a parent of your text. By making
it smaller, either the text is no longer within the parent or the size of
the parent is too small to show the text at all.
You need to take care that when making a PictogramElement smaller all its
children are placed at a location that is really inside the parent, because
the parent will clip at its borders.
Michael
Re: Set Text to the right position [message #893856 is a reply to message #893707] Thu, 05 July 2012 17:21 Go to previous messageGo to next message
Hi Michael,
thanks for that answer. The innerpictogrammelements should be at there origin postion, because the feature scould be a collapse feature. The Problem is, that the text is at its origin postion too. Now I want to know how could i change that postion the the visible area?
Michael Wenz wrote on Thu, 05 July 2012 06:23
Michael
Re: Set Text to the right position [message #893943 is a reply to message #893856] Fri, 06 July 2012 07:04 Go to previous messageGo to next message
I think I didn't understand that...
The visible area is always at 0,0 (starting in the left upper corner) of the
parent shape's Graphic Algorithm. Its size is as large as the GA is defined.
Michael
Re: Set Text to the right position [message #894000 is a reply to message #893943] Fri, 06 July 2012 11:27 Go to previous messageGo to next message
Ok I have a pictogramelement with other pictogrammelements inside. So i made the "overpictogrammelement" smaller, to hiding the the other elements. What would happen if I made the shape smaller to? Would this change the Position of the innerpictogramelements too?
Re: Set Text to the right position [message #894406 is a reply to message #894000] Mon, 09 July 2012 06:47 Go to previous message
Hm, Graphiti uses two concepts for the graphical representations: The
pictogram elements (PE) define the hierarchie of the shapes in the diagram,
they consists of nested ContainerShapes and Shapes; there is no size or
location information on these elements.
Then there are Graphics Alhorithms (GA) (like Rectangle, Text,...); they are
attached to a shape or container shape (in fact each of the pictogram
elements must have one Graphics Algorithm) and define the look (color etc)
and the size and location.
So by nesting PEs there associated GAs define what is visible from the
children. Each PE spans its own coordinate system, so GAs use a location
realative to the parent PEs GA. Also the parent PEs GA defines the size,
everything from the children that reaches beyond this size is clipped.
Michael
Previous Topic:Changing Palette
Next Topic:First Editor
Current Time: Sat May 15 19:37:19 GMT 2021
Powered by FUDForum. Page generated in 0.02576 seconds
