Re: SimpleIDE compilation problem [message #893511 is a reply to message #893509] |
Wed, 04 July 2012 12:02 |
Marek Jasovsky Messages: 23 Registered: July 2012 |
my target platform contains then, but how to include one particular jar, to run configuration, so that it is included in classpath / packaged when I export whole app? this am I struggling somehow. when I manually added it to artifacts.xml and config.ini, then I could start it, but only as standalone app. not from eclipse.
thanks a lot for your help so far
Marek
Oliver Koch wrote on Wed, 04 July 2012 07:59You must make sure that your target platform contains the swt bundles
for your architecture/platform and that they are included in your run
configuration.
Am 04.07.2012 13:36, schrieb Marek Jasovsky:
> Neither start through exported standalone app works. it seems, that in
> export, there is not the real swt.jar included, that's why it cannot
> find swt classes.
> any idea how to solve this?
> Thanks in advance
> Marek
Re: SimpleIDE compilation problem [message #893512 is a reply to message #893511] |
Wed, 04 July 2012 12:06 |
Oliver Koch Messages: 40 Registered: June 2012 |
Member |
you have to click on add required plugins in the run configuration (the
plug-ins tab).
you could click the validate button in the product file, too
Am 04.07.2012 14:02, schrieb Marek Jasovsky:
> Hi
> Marek
>> configuration.
>> > find swt classes.
>> > Thanks in advance
>> > Marek
FUDForum. Page generated in 0.04114 seconds
