Error in generated refreshSemantic() [message #893240] |
Tue, 03 July 2012 10:16 |
Nikolay Manolov Messages: 24 Registered: June 2012 |
Eugenia generates everything successfully (so it says) but then there are some errors in package.diagram.edit.policies in some of the <nodeName>CanonicalEditPolicy.java files.
the error appears in the following snippet
protected void refreshSemantic() {
if (resolveSemanticElement() == null) {
return;
LinkedList<IAdaptable> createdViews = new LinkedList<IAdaptable>();
List<TransportingNodeDescriptor> childDescriptors = TransportingDiagramUpdater
.getCustomer_2003SemanticChildren((View) getHost().getModel()); // !!! The method getCustomer_2003SemanticChildren(View) is undefined for the type TransportingDiagramUpdater
LinkedList<View> orphaned = new LinkedList<View>();
// we care to check only views we recognize as ours
LinkedList<View> knownViewChildren = new LinkedList<View>();
for (View v : getViewChildren()) {
if (isMyDiagramElement(v)) {
knownViewChildren.add(v);
it is always in the refreshSemantic function and the error is
"The method getCustomer_2003SemanticChildren(View) is undefined for the type TransportingDiagramUpdater"
it suggests that the name is changed to getSemanticChildren(). If I do that manually it seems to work. But I have to change it in a lot of files.
If ignore the error and start the Editor. I manage to open it but when I start "drawing" it stops responding. I wouldn't know if that is a problem with my .emf file because the editor sporadically crashes anyways (I am still learning).
I don't know if those errors and correcting them matter at all, since after I correct the errors , no code is being generated. I just proceed to start the editor.
My .emf file looks like this
@namespace(uri="transporter", prefix="transporter")
@gmf(foo="bar")
package transporting;
@gmf.diagram(foo="bar")
class Logistics {
val Stuff[*] stuff;
val Customer[*] customers;
val Transporter[*] transporters;
//val Llabel[*] labels;
val Box[*] boxes;
class Node{
attr String name;
@gmf.node(label="name")
class Customer extends Node{
@gmf.link(sytle="dash")
ref Llabel[*] belongs_to;
@gmf.link(target.decoration="arrow", sytle="dash")
class Customer_Owns_Box{
ref Customer source;
ref Box target;
class Stuff extends Node{
class Box extends Stuff{
@gmf.link(label="member")
val Llabel[*] on;
@gmf.compartment(foo="bar")
val Stuff[*] contents;
@gmf.node(label="name", phantom="true")
class Llabel extends Node{
class Transporter extends Node{
val Box[*] boxes;
Any ideas?
EDIT:
Actually fixing the errors in the java code does seem to affect the Editor for the better. It crashes only when I try to place The label node in the diagram. So I am guessing the problem lies within the label. Still I am clueless.
EDIT2:
Actually just starting the a new Eclipse instance produces an error
!ENTRY org.eclipse.gmf.runtime.diagram.ui 4 2 2012-07-03 12:41:18.516
!MESSAGE IRJS0007E Semantic refresh failed.
!STACK 0
java.lang.ClassCastException: phantom.impl.MemberImpl cannot be cast to phantom.Model
at phantom.diagram.part.PhantomDiagramUpdater.getModel_1000SemanticChildren(PhantomDiagramUpdater.java:61)
at phantom.diagram.edit.policies.MemberCanonicalEditPolicy.refreshSemantic(MemberCanonicalEditPolicy.java:81)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEditPolicy.refresh(CanonicalEditPolicy.java:961)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEditPolicy.refreshOnActivate(CanonicalEditPolicy.java:638)
at phantom.diagram.edit.policies.MemberCanonicalEditPolicy.refreshOnActivate(MemberCanonicalEditPolicy.java:45)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEditPolicy.activate(CanonicalEditPolicy.java:628)
at org.eclipse.gef.editparts.AbstractEditPart.activateEditPolicies(AbstractEditPart.java:174)
at org.eclipse.gef.editparts.AbstractEditPart.activate(AbstractEditPart.java:156)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.activate(AbstractGraphicalEditPart.java:195)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.access$0(GraphicalEditPart.java:1)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.activate(GraphicalEditPart.java:205)
at phantom.diagram.edit.policies.ModelCanonicalEditPolicy.refreshOnActivate(ModelCanonicalEditPolicy.java:56)
at org.eclipse.gmf.runtime.diagram.ui.editparts.DiagramEditPart.activate(DiagramEditPart.java:349)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:215)
at org.eclipse.gef.editparts.SimpleRootEditPart.setContents(SimpleRootEditPart.java:105)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:617)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalViewer.setContents(DiagramGraphicalViewer.java:352)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:626)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.initializeGraphicalViewerContents(DiagramEditor.java:872)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.initializeGraphicalViewer(DiagramEditor.java:865)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFlyOutPalette.initializeGraphicalViewer(DiagramEditorWithFlyOutPalette.java:116)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.initializeGraphicalViewer(DiagramDocumentEditor.java:174)
at phantom.diagram.part.PhantomDiagramEditor.initializeGraphicalViewer(PhantomDiagramEditor.java:317)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.createGraphicalViewer(DiagramEditor.java:807)
at org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(GraphicalEditor.java:171)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.createPartControl(DiagramEditor.java:1580)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFlyOutPalette.createPartControl(DiagramEditorWithFlyOutPalette.java:328)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.createPartControl(DiagramDocumentEditor.java:1510)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1459)
at org.eclipse.ui.internal.EditorManager$5.runWithException(EditorManager.java:972)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1600)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Best Regards,
Nik
[Updated on: Tue, 03 July 2012 10:44] Report message to a moderator
FUDForum. Page generated in 0.03538 seconds
