Home » Archived » BIRT » birt when group count is equal to page break in next page extra group header appears with no data(birt group count is equal to page break on the table then next group header repeat with no data )
birt when group count is equal to page break in next page extra group header appears with no data [message #893174] |
Tue, 03 July 2012 05:28 |
ramesh pulipati Messages: 6 Registered: July 2012 |
I am facing the problem when the group count of records is equal to page break, then only the case the next group header displaying with out data .
Much appreciate for your help.
I have attached the report
please go to the record 10103(order number) after the order 10103 page break happend, in the next page 10104 group header comes with no data, then click next page there group header 10104 and data appears. i dont know why the extra group header comes with no data.
Note: View the report in Web Viewer.
This is happend only when the group count of records and page break number are equall.
Ramesh Pulipati
[Updated on: Tue, 03 July 2012 05:33] Report message to a moderator
Re: birt when group count is equal to page break in next page extra group header appears with no dat [message #893768 is a reply to message #893174] |
Thu, 05 July 2012 13:32 |
Can you try setting the page break interval for the table to 0?
See attached.
Jason
On 7/3/2012 1:28 AM, ramesh ramesh wrote:
> Hi
> please go to the record 10103(order number) after the order 10103 page break happend, in the next page 10104 group header comes with no data, then click next page there group header 1014 and data appears. i dont know why the extra group header comes with no data.
> Regards,
> Ramesh Pulipati
Attachment: group.zip
(Size: 2.86KB, Downloaded 238 times)
Re: birt when group count is equal to page break in next page extra group header appears with no dat [message #893773 is a reply to message #893174] |
See attached.
Jason
> Hi
> Regards,
> Ramesh Pulipati
(Size: 2.86KB, Downloaded 244 times)
Re: birt when group count is equal to page break in next page extra group header appears with no dat [message #893776 is a reply to message #893174] |
See attached.
Jason
> Hi
> Regards,
> Ramesh Pulipati
(Size: 2.86KB, Downloaded 229 times)
Re: birt when group count is equal to page break in next page extra group header appears with no dat [message #893777 is a reply to message #893174] |
See attached.
Jason
> Hi
> Regards,
> Ramesh Pulipati
(Size: 2.86KB, Downloaded 202 times)
Re: birt when group count is equal to page break in next page extra group header appears with no dat [message #893782 is a reply to message #893174] |
See attached.
Jason
> Hi
> Regards,
> Ramesh Pulipati
(Size: 2.86KB, Downloaded 231 times)
Re: birt when group count is equal to page break in next page extra group header appears with no dat [message #893787 is a reply to message #893174] |
See attached.
Jason
> Hi
> Regards,
> Ramesh Pulipati
(Size: 2.86KB, Downloaded 249 times)
Re: birt when group count is equal to page break in next page extra group header appears with no dat [message #893788 is a reply to message #893174] |
See attached.
Jason
> Hi
> Regards,
> Ramesh Pulipati
Re: birt when group count is equal to page break in next page extra group header appears with no dat [message #894072 is a reply to message #893912] |
Fri, 06 July 2012 14:30 |
If you put the interval to 0 you will get a page break when the space is
used determined by the master page size. You may want to upgrade to one
of the newer versions which appear to handle this scenario better.
Jason
On 7/5/2012 10:29 PM, ramesh ramesh wrote:
> Hi Jason Weathersby
> Sorry for late reply
> i have a requirement that in a page if the group has more then 20
> records then the page break happend,
> so pagebreak interval is 20.
> if we set page break interval to 0 then the page break happend ?
> Please advice on this issue
> Regards,
> Ramesh Pulipati
Re: birt when group count is equal to page break in next page extra group header appears with no dat [message #894641 is a reply to message #894465] |
Mon, 09 July 2012 23:25 |
In the example attached, if you set the page break interval to 0, create two aggregations on the table (one running count on the group and one total count on the group), and put the following script, which uses the two aggregations to handle your in group page breaking, in the onCreate of your detail row, it should stop the repeated headers and if you put a page number auto text in the masterpage footer, it'll be correct, as well. Leave the groups page break after set to always excluding last.
if (row["GroupCount"] == row["GroupRunningCount"]){
else{
if(row["GroupRunningCount"]%10 == 0){
this.getStyle().pageBreakAfter = "always";
Hope this helps.
Michael
Developer Evangelist, Silanis
Current Time: Thu Apr 18 14:10:49 GMT 2024
Powered by FUDForum. Page generated in 0.01930 seconds
