Recursion without recursion? [message #893033] |
Mon, 02 July 2012 11:44 |
Hannes Müller Messages: 24 Registered: June 2012 |
Hello everyone,
Ok, I have a problem while defining a dsl where formulas like a * (b / 2) should be written. I get errors all the time and after some hours I don't know how to proceed without help. Does enyone knows what the error message means (see error message below)? Or even better why the errors occur (see code below)? I don't see a left recursion like the ones descriped in the documentation (or in one of the blogs of one of the guys who are responsible for xtext).
The following error message occurs (more than once):
"warning(200): ../org.xtext.scannerdomainmodel/src-gen/org/xtext/example/mydsl/parser/antlr/internal/InternalMyDsl.g:1089:2: Decision can match input such as "'+' RULE_ID" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input"
Here is the relevant part of my xtext-file:
RecalculateFormula:
complexFormula = ComplexFormula
Operant:
parameter = [ParameterWithRecalculate] | integer = INT
SimpleFormulaWithoutBrackets:
leftOperant = Operant (operators += FormulaOperator operants += Operant)*
SimpleFormulaWithBrackets:
'('SimpleFormulaWithoutBrackets')'
SimpleFormularWithOptionalBrackets:
simpleFormularWithoutBrackets = SimpleFormulaWithoutBrackets | simpleFormulaWithBrackets = SimpleFormulaWithBrackets
ComplexFormula:
leftFormula = SimpleFormularWithOptionalBrackets (operators += FormulaOperator formulas += SimpleFormularWithOptionalBrackets)*
I have an additional hint:
When I only use the SimpleFormulaWithBrackets rule instead of the SimpleFormularWithOptionalBrackets rule in the ComplexFormula rule it works. But I want optional brackets!
And: If I want to add the following Rule to the operants again those error messages occur:
Operant:
parameter = [ParameterWithRecalculate] | integer = INT //| double = Double
Double:
predecimalNumber = INT('.'decimalNumber = INT)?
I would be gratefule for any hint.
THX in advance
Hannes
[Updated on: Mon, 02 July 2012 12:10] Report message to a moderator
FUDForum. Page generated in 0.03058 seconds
