Re: No Customize perspective in Juno ??? [message #898853 is a reply to message #892531] |
Sat, 28 July 2012 05:02 |
I also wanna customize my perspective, specially the toolbar. It works but:
as you can see, there are no entries at "Menubar Details" and "Toolbar details" regardless of which category is selected.
I'm not so familiar with Bugzilla, so I have not reported this bug there, maybe someone else has already done it.
Rico
[Updated on: Sat, 28 July 2012 05:04] Report message to a moderator
Re: No Customize perspective in Juno ??? [message #899070 is a reply to message #898853] |
Mon, 30 July 2012 13:24 |
Enrico-
I will look into this a little today and see what I am able to find. I can say that there is still a mix of commands & actions used by the workbench which may interfere a little. Also, it does not look like all command categories are being reported to the model (mere observation of the live model).
Primarily though, there still isn't a defined "editor" in Eclipse4, this will be one of the major feature enhancements in 4.3.
What I will look into more is the interoperability of 3.x plugins and the 3.x editor through the compatibility layer. There may well be some missing parts on the compatibility layer that are causing your issues. (Assuming you are using the compat layer).
But I'll take a look.
JD
Re: No Customize perspective in Juno ??? [message #899088 is a reply to message #899070] |
Mon, 30 July 2012 14:18 |
Thanks Joseph!
The picture in my post is from a standard "Eclipse 4.2 SDK" installation, i don't have installed any Plugins and made no configuration....I've simply started Eclipse selected a new workspace. Nothing more.
Maybe it is relevant.
Thanks for your effort.
Enrico
Re: No Customize perspective in Juno ??? [message #899400 is a reply to message #899088] |
Tue, 31 July 2012 17:01 |
Enrico-
Effectively, the issue is that the 'available command groups' points to the old actions registry and not to the model. Thus when the list of menu contributions from the application model is filtered against the selection, all of the elements are filtered out.
I am not familiar enough with the code to solve this issue right now. But this is a valid bug, please file a bugzilla [1] with your general description from above and paste a link to the bug here. I can only speculate, however I wouldn't expect to see any movement on this until 4.2.2 at the earliest (February).
JD
[1] http://bugs.eclipse.org/bugs/
Re: No Customize perspective in Juno ??? [message #899612 is a reply to message #899565] |
Wed, 01 August 2012 14:56 |
Just updated the bug with my findings, thanks.
IMHO, I doubt this will be addressed before 4.3. There are too many other things that need work. Plus once the workbench model includes a MDialog, the perspective customization dialog will have to undergo a complete refactorization any ways. So it wouldn't make sense to do this twice.
But that is pure speculation, and the fix could end up being very straight forward. We'll see what others have to say!
JD
FUDForum. Page generated in 0.04029 seconds
