Home » Modeling » EMF » Collecting XMI files backing an entire EMF Model
Re: Collecting XMI files backing an entire EMF Model [message #892244 is a reply to message #892201] |
Wed, 27 June 2012 13:34 |
Ed Merks Messages: 33141 Registered: July 2009 |
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Vinny,<br>
<br>
Comments below.<br>
<br>
<div class="moz-cite-prefix">On 27/06/2012 1:53 PM, Vinny Vallarine
wrote:<br>
</div>
<blockquote cite="mid:jses8c$gjv$1@xxxxxxxxe.org" type="cite">But
I still need to traverse through to get to each file, correct? <br>
</blockquote>
Yes, you need to visit all reachable objects.<br>
<blockquote cite="mid:jses8c$gjv$1@xxxxxxxxe.org" type="cite">Below
is my current implementation. It works 100% of the time but I
think I have extra looping and/or wasted processing going on. I'm
just not sure where. I'd appreciate a quick look. Again, this
"lookup" needs to follow all possible paths from the top level
node, both containment and non-containment. So, in summary, is
this logic the most efficient way to build a list of files that
back my entire EMF model?
<br>
<br>
<br>
<br>
* Recursive method that will traverse down an EObjects containment
and/or
<br>
* non containment objects and add all the EObject's URI file paths
to the
<br>
* file name list this class is managing.
<br>
* * NOTE: !!!This method is recursive!!!
<br>
* * @param object
<br>
* The EObject root node starting point
<br>
<br>
private void addContentFiles(final EObject object){
<br>
<br>
if (object != null) {
<br>
<br>
//recurse for all of this object's containment references
<br>
for (EObject containedRefs : object.eContents()) {
<br>
this.addContentFiles(containedRefs, monitor);
<br>
<br>
</blockquote>
If you used eAllContents, you could avoid the need for recursion.<br>
<br>
<br>
for (EObject nonContainedRefs : object.eCrossReferences())
<br>
this.addContentFiles(nonContainedRefs, monitor);
<br>
<br>
</blockquote>
You might want a content tree many times this way.<br>
<br>
String fileName = null;
<br>
if (object.eIsProxy() && (object instanceof
InternalEObject)) {
<br>
</blockquote>
There's no need for the second guard. All EObjects <b>must </b>implement
InternalEObject.<br>
fileName = ((InternalEObject) object).eProxyURI().toFileString();
<br>
</blockquote>
It's not generally good to assume it's a file: URI; maybe that's
okay in your case.<br>
} else {
<br>
if ((object.eResource() != null) &&
(object.eResource().getURI() != null)) {
<br>
fileName =
object.eResource().getURI().toFileString();
<br>
<br>
<br>
<br>
if (fileName != null) {
<br>
//WE FOUND A NEW FILE, ADD IT TO OUR LIST FOR USE LATER
<br>
myRunningFileList.add(fileName);
<br>
<br>
<br>
</blockquote>
I'm not sure the significance of starting with a specific object.
In general an EObject might have an eContainer(); wouldn't you want
to visit that? Did you look at what EcoreUtil.resolveAll does for a
resource set? Assuming you start with a single object in your
resource set, that method will yield a resource set containing all
reachable resources.<br>
<br>
Failing that, you'd be better to add a guard so that you don't visit
the same object more than once. I.e., a set of visited objects and
only if add returns true do you visit it.<br>
<br>
</body>
</html>
Ed Merks
Re: Collecting XMI files backing an entire EMF Model [message #892265 is a reply to message #892253] |
Wed, 27 June 2012 14:24 |
Vinny,
Comments below.
On 27/06/2012 3:58 PM, Vinny Vallarine wrote:
> We've implemented an "Export" feature which, among other things,
> creates a file archive of the XMI files that back the EMF model. The
> significance of starting with a specific object is that the user can
> 'export' at any level of our model hierarchy. If the model hierarchy,
> e.g., looks like A contains B contains C refers to D, the user could
> export at "B" so I'd have to pull in the backing files for object B, C
> and D.
> Couple more questions: 1. What did you mean by "You might want a
> content tree many times this way"?
Sorry I mean "walk" not "want".
> 2. Can I avoid, all together, calling eCrossReferences()? I figured I
> had to get at all the non contained references?
No, you'd want to know about D, so you just visit cross references. But
you might visit D more than once, in general, and you walk the whole
content tree below D so all that extra visiting could be expensive.
What if D is contained by E? Wouldn't you need to visit E as well given
that E might reference F which could be in another resource you'd not
reach otherwise?
Ed Merks
Re: Collecting XMI files backing an entire EMF Model [message #892599 is a reply to message #892552] |
Thu, 28 June 2012 16:50 |
Vinny,
Comments below.
On 28/06/2012 5:31 PM, Vinny Vallarine wrote:
> I think I can simplify via:
> public void addAllContentFiles(EObject eObject,
> IProgressMonitor monitor) throws
> InterruptedException {
> if (!this.objectsAlreadyVisited.add(eObject)) {
> return;
> //SAVE THE FILE THAT BACKS THIS OBJECT
> this.saveFile(eObject);
Presumably you're making sure to collect all the resources so you only
save each resource once...
> for (EObject containedObject : eObject.eContents()) {
> this.addAllContentFiles(containedObject, monitor);
> for (EObject innerEObject : eObject.eCrossReferences()) {
> this.addAllContentFiles(innerEObject, monitor); //????
> My questions: 1. Any obvious missteps?
> 2. Do I need to recursively call myself for each crossReference? Note
> the "????" in the code
You'd not save referenced resources without this recursive call, right?
And you want to save resources referenced from this cross reference's
resource too, presumably, right?
> PS: I know this has turned into a mini code review but it is helping,
> and I do appreciate it.
Ed Merks
Current Time: Thu Apr 25 20:28:39 GMT 2024
Powered by FUDForum. Page generated in 0.03634 seconds
