Re: BIRT chart engine issue [message #891995 is a reply to message #891952] |
Tue, 26 June 2012 19:12 |
What version of BIRT are you using and how do you call it?
Jason
On 6/26/2012 12:28 PM, tanmay varma wrote:
> Can someone please help me with this error.
> Jun 26, 2012 10:20:25 AM
> org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher
> renderReport
> SEVERE: Engine exception
> org.eclipse.birt.report.engine.api.EngineException: Failed to initialize
> emitter.
> at
> org.eclipse.birt.report.engine.emitter.EmitterUtil.getOuputStream(EmitterUtil.java:82)
> at
> org.eclipse.birt.report.engine.emitter.html.HTMLReportEmitter.initialize(HTMLReportEmitter.java:352)
> at
> org.eclipse.birt.report.engine.api.impl.EngineTask.initializeContentEmitter(EngineTask.java:2205)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:117)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
> at
> org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.createReport(ReportLauncher.java:594)
> at
> org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.renderReport(ReportLauncher.java:541)
> at
> org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.run(ReportLauncher.java:455)
> at
> org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.main(ReportLauncher.java:104)
> at
> org.eclipse.birt.report.debug.internal.core.ReportDebugger.start(ReportDebugger.java:39)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
> Caused by: java.io.FileNotFoundException: \new_report.rptdesign.html (A
> required privilege is not held by the client)
> at java.io.FileOutputStream.open(Native Method)
> at java.io.FileOutputStream.<init>(Unknown Source)
> at
> org.eclipse.birt.report.engine.emitter.EmitterUtil.getOuputStream(EmitterUtil.java:77)
> ... 22 more
> org.eclipse.birt.report.debug.internal.core.vm.ReportVMServer$1 run
> WARNING: [Server] client disconnected
> Thank You
> Tanny
Re: BIRT chart engine issue [message #892043 is a reply to message #892002] |
Wed, 27 June 2012 00:30 |
Is this Java Code? If so have you setup a Java project?
Jason
On 6/26/2012 3:36 PM, tanmay varma wrote:
> Hey Jason ,
> its 3.7.2
> and right now I am just clicking on "Debug as" and then click on "Report"
> because its not giving me any other option.
> I am new to BIRT so Im still learning
> Thank You
> Tanny
FUDForum. Page generated in 0.02898 seconds
