Home » Archived » BIRT » Problem with Script Datasource(Getting error running a java script)
Problem with Script Datasource [message #891916] |
Tue, 26 June 2012 14:46 |
Carlos Ferrer Messages: 18 Registered: July 2009 |
On BIRT version 3.7.2
I have encountered an issue when doing a data script birt report(My first one). I compiled and jarred the classes successfully. I verified that I have the most current version of the jar.
I created the following for open():
importPackage(Packages.birtjava.tdcj.ProdDb2Test);
count = 0;
prodDb2Test = new Packages.birtjava.tdcj.ProdDb2Test();
ntoNcrList = prodDb2Test.build();
fetch():
while(count < ntoNcrList.size())
row["email"] = ntoNcrList.get(count).getNeoEmail();
row["userid"] = ntoNcrList.get(count).getNeoNtouserid();
row["rptType"] = ntoNcrList.get(count).getNelRptType();
count++;
return true;
return false;
Additional information: Per other programmers here, I placed the jar file in the same location as the .rptdesign file.
When I did a Preview I encountered the following error:
The following items have errors:
ReportDesign (id = 1):
+ There are errors evaluating script "importPackage(Packages.birtjava.tdcj.ProdDb2Test);
count = 0;
Fail to execute script in function __bm_OPEN(). Source:
" + importPackage(Packages.birtjava.tdcj.ProdDb2Test);
count = 0;
A BIRT exception occurred. See next exception for more information.
Error evaluating Javascript expression. Script engine error: TypeError: [JavaPackage birtjava.tdcj.ProdDb2Test] is not a function, it is object. (/report/data-sets/script-data-set[@id="8"]/method[@name="open"]#5)
Script source: /report/data-sets/script-data-set[@id="8"]/method[@name="open"], line: 0, text:
__bm_OPEN(). (Element ID:1)
Error.ScriptEvaluationError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "importPackage(Packages.birtjava.tdcj.ProdDb2Test);
count = 0;
count = 0;
at org.eclipse.birt.report.engine.script.internal.DtEScriptExecutor.handleJS(DtEScriptExecutor.java:99)
at org.eclipse.birt.report.engine.script.internal.DataSetScriptExecutor.handleJS(DataSetScriptExecutor.java:256)
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:98)
at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open(ScriptDataSetRuntime.java:80)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.java:247)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java:223)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1134)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:177)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init>(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:267)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1939)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:929)
at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageAllActionHandler.__execute(BirtGetPageAllActionHandler.java:131)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPageAll(BirtDocumentProcessor.java:183)
at sun.reflect.GeneratedMethodAccessor34.invoke(Unknown Source)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at sun.reflect.GeneratedMethodAccessor33.invoke(Unknown Source)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:317)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:939)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Caused by: org.eclipse.birt.data.engine.core.DataException: Fail to execute script in function __bm_OPEN(). Source:
count = 0;
__bm_OPEN()
at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript(JSMethodRunner.java:147)
at org.eclipse.birt.report.engine.script.internal.DtEScriptExecutor.handleJS(DtEScriptExecutor.java:90)
... 70 more
Caused by: org.eclipse.birt.data.engine.core.DataException: A BIRT exception occurred. See next exception for more information.
__bm_OPEN()
at org.eclipse.birt.data.engine.core.DataException.wrap(DataException.java:123)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJSAsExpr(ScriptEvalUtil.java:996)
at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript(JSMethodRunner.java:138)
... 71 more
Caused by: org.eclipse.birt.core.exception.CoreException: Error evaluating Javascript expression. Script engine error: TypeError: [JavaPackage birtjava.tdcj.ProdDb2Test] is not a function, it is object. (/report/data-sets/script-data-set[@id="8"]/method[@name="open"]#5)
__bm_OPEN()
at org.eclipse.birt.core.script.JavascriptEvalUtil.wrapRhinoException(JavascriptEvalUtil.java:303)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawScript(JavascriptEvalUtil.java:102)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScript(JavascriptEvalUtil.java:134)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJSAsExpr(ScriptEvalUtil.java:992)
... 72 more
Caused by: org.mozilla.javascript.EcmaError: TypeError: [JavaPackage birtjava.tdcj.ProdDb2Test] is not a function, it is object. (/report/data-sets/script-data-set[@id="8"]/method[@name="open"]#5)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3654)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3632)
at org.mozilla.javascript.ScriptRuntime.typeError(ScriptRuntime.java:3660)
at org.mozilla.javascript.ScriptRuntime.typeError2(ScriptRuntime.java:3679)
at org.mozilla.javascript.ScriptRuntime.notFunctionError(ScriptRuntime.java:3734)
at org.mozilla.javascript.ScriptRuntime.notFunctionError(ScriptRuntime.java:3722)
at org.mozilla.javascript.ScriptRuntime.newObject(ScriptRuntime.java:2324)
at org.mozilla.javascript.gen.c30._c1(/report/data-sets/script-data-set[@id="8"]/method[@name="open"]:5)
at org.mozilla.javascript.gen.c30.call(/report/data-sets/script-data-set[@id="8"]/method[@name="open"])
at org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRuntime.java:108)
at org.mozilla.javascript.gen.c8._c0(/report/data-sets/script-data-set[@id="8"]/method[@name="open"]:0)
at org.mozilla.javascript.gen.c8.call(/report/data-sets/script-data-set[@id="8"]/method[@name="open"])
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:398)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3065)
at org.mozilla.javascript.gen.c8.exec(/report/data-sets/script-data-set[@id="8"]/method[@name="open"])
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawScript(JavascriptEvalUtil.java:95)
... 74 more
+ There are errors evaluating script "while(count < ntoNcrList.size())
count++;
return true;
return false;":
Fail to execute script in function __bm_FETCH(). Source:
" + while(count < ntoNcrList.size())
count++;
return true;
return false; + "
Error evaluating Javascript expression. Script engine error: ReferenceError: "ntoNcrList" is not defined. (/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"]#1)
Script source: /report/data-sets/script-data-set[@id="8"]/method[@name="fetch"], line: 0, text:
__bm_FETCH(). (Element ID:1)
detail : org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "while(count < ntoNcrList.size())
count++;
return true;
return false;":
count++;
return true;
return false; + "
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:143)
at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.fetch(ScriptDataSetRuntime.java:103)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor$CustomDataSet.fetch(PreparedScriptDSQuery.java:260)
at org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch(OdiAdapter.java:226)
at org.eclipse.birt.data.engine.executor.cache.RowResultSet.doNext(RowResultSet.java:113)
at org.eclipse.birt.data.engine.executor.cache.RowResultSet.next(RowResultSet.java:91)
at org.eclipse.birt.data.engine.executor.cache.ExpandableRowResultSet.next(ExpandableRowResultSet.java:63)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.populateData(SmartCacheHelper.java:316)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.initInstance(SmartCacheHelper.java:285)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.getResultSetCache(SmartCacheHelper.java:246)
at org.eclipse.birt.data.engine.executor.cache.SmartCache.<init>(SmartCache.java:73)
at org.eclipse.birt.data.engine.executor.transform.pass.PassUtil.populateOdiResultSet(PassUtil.java:110)
at org.eclipse.birt.data.engine.executor.transform.pass.PassUtil.pass(PassUtil.java:62)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.doSinglePass(PassManager.java:170)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.prepareDataSetResultSet(PassManager.java:94)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.pass(PassManager.java:134)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.populateResultSet(PassManager.java:74)
at org.eclipse.birt.data.engine.executor.transform.ResultSetPopulator.populateResultSet(ResultSetPopulator.java:198)
at org.eclipse.birt.data.engine.executor.transform.CachedResultSet.<init>(CachedResultSet.java:195)
at org.eclipse.birt.data.engine.executor.CandidateQuery.execute(CandidateQuery.java:154)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java:226)
Caused by: org.eclipse.birt.data.engine.core.DataException: Fail to execute script in function __bm_FETCH(). Source:
count++;
return true;
return false; + "
__bm_FETCH()
... 87 more
__bm_FETCH()
... 88 more
Caused by: org.eclipse.birt.core.exception.CoreException: Error evaluating Javascript expression. Script engine error: ReferenceError: "ntoNcrList" is not defined. (/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"]#1)
__bm_FETCH()
... 89 more
Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "ntoNcrList" is not defined. (/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"]#1)
at org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRuntime.java:3717)
at org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRuntime.java:1758)
at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java:1697)
at org.mozilla.javascript.gen.c20._c1(/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"]:1)
at org.mozilla.javascript.gen.c20.call(/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"])
at org.mozilla.javascript.gen.c10._c0(/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"]:0)
at org.mozilla.javascript.gen.c10.call(/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"])
at org.mozilla.javascript.gen.c10.exec(/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"])
... 91 more
+ Data Set script method "Fetch" returned null; expected a Boolean value. (Element ID:1)
data.engine.BadFetchScriptReturnType ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Data Set script method "Fetch" returned null; expected a Boolean value. (Element ID:1)
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:244)
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:233)
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:165)
Caused by: org.eclipse.birt.data.engine.core.DataException: Data Set script method "Fetch" returned null; expected a Boolean value.
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:153)
... 85 more
Is below the problem? If so how do I get around this?
Thanks for your help.
Re: Problem with Script Datasource [message #891994 is a reply to message #891916] |
Tue, 26 June 2012 19:11 |
Carlos
Where did you put the jar?
Also change:
to
importPackage(Packages.birtjava.tdcj);
prodDb2Test = new ProdDb2Test();
Jason
> count = 0;
> fetch():
> count++;
> return true;
> return false;
> ReportDesign (id = 1): + There are errors evaluating script
> count = 0;
> count = 0;
> Script source:
> 0, text:
> __bm_OPEN(). (Element ID:1) Error.ScriptEvaluationError ( 1 time(s) )
> count = 0;
> count = 0;
> Script source:
> 0, text:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> count = 0;
> Script source:
> 0, text:
> __bm_OPEN()
> at
> at
> ... 70 more
> Script source:
> 0, text:
> __bm_OPEN()
> at
> at
> at
> ... 71 more
> Script source:
> 0, text:
> __bm_OPEN()
> at
> at
> at
> at
> ... 72 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 74 more
> ntoNcrList.size())
> count++;
> return true;
> return false;":
> count++;
> return true;
> return false; + "
> Script source:
> 0, text:
> __bm_FETCH(). (Element ID:1) Error.ScriptEvaluationError ( 1 time(s) )
> count++;
> return true;
> return false;":
> count++;
> return true;
> return false; + "
> Script source:
> 0, text:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> count++;
> return true;
> return false; + "
> Script source:
> 0, text:
> __bm_FETCH()
> at
> at
> ... 87 more
> Script source:
> 0, text:
> __bm_FETCH()
> at
> at
> at
> ... 88 more
> Script source:
> 0, text:
> __bm_FETCH()
> at
> at
> at
> at
> ... 89 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 91 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 85 more
Current Time: Tue Apr 23 13:04:15 GMT 2024
Powered by FUDForum. Page generated in 0.03434 seconds
