Home » Modeling » EMF » [XCore] Overriding implementation of a super class feature in a subclass
[XCore] Overriding implementation of a super class feature in a subclass [message #891648] Mon, 25 June 2012 12:04 Go to next message
Roland Tepp is currently offline Roland TeppFriend
Member
I have a legacy model I want to model (I am using XCore for this) in EMF.
Basically the legacy model is a table that has tons of columns. Most of
these columns are only filled if the "type" column has a certain value.
I decided to model this table using class inheritance with one base
class for common features and a subclass for each type of the entity
with the additional features relevant to the particular type defined
inside this subclass.
I would also like to provide the abstract "type" feature in the base
class that would return the value of the "type" column of the table.
Essentially the value of the Type feature would be constant for a
particular subclass, but I can not specify an override for a feature
(xcore reports an error when I try to specify a field that is already
defined for a superclass)
What are my options in this case? Can this be done?
Re: [XCore] Overriding implementation of a super class feature in a subclass [message #891722 is a reply to message #891648] Mon, 25 June 2012 15:38 Go to previous messageGo to next message
Roland,
Comments below.
On 25/06/2012 2:04 PM, Roland Tepp wrote:
> of these columns are only filled if the "type" column has a certain
> value.
And it must be a feature, i.e., an operation won't suffice?
You should be able to define an operation that has the same name as the
accessor method for the feature.
Re: [XCore] Overriding implementation of a super class feature in a subclass [message #891883 is a reply to message #891722] Tue, 26 June 2012 12:28 Go to previous messageGo to next message
Member
Thanks Ed for quick reply,
My comments below as well:
25.06.2012 18:38, Ed Merks kirjutas:
I suppose, an operation would do just as well... Feature would simply
"look better" in this context.
Okay, so let me confirm that I understand it correctly:
I can define:
enum Type {
ONE
TWO
THREE
abstract class Base {
derived transient readonly Type ^type
class One extends Base {
op Type getType(){
return Type::ONE
etc.
It looks like a hackish solution, but it seems to work well enough.
Roland
Re: [XCore] Overriding implementation of a super class feature in a subclass [message #891885 is a reply to message #891883] Tue, 26 June 2012 12:33 Go to previous message
Roland,
Yes, that's the idea.
> I can define:
> enum Type {
> ONE
> TWO
> THREE
> op Type getType(){
> return Type::ONE
> etc.
> Thanks :)
> Roland
Previous Topic:Read-only resource in resourceset
Next Topic:EMap and resolved keys
Current Time: Thu Feb 20 12:12:05 GMT 2020
Powered by FUDForum. Page generated in 0.04314 seconds
