[Compare] DiffEngine: Modifying when Conflicting EReferences occur [message #118975] |
Fri, 18 April 2008 07:31 |
Matt Seashore Messages: 58 Registered: July 2009 |
Member |
When running a Diff, I need (non-containment) EReferences to be
evaluated just by the *URIs* they point to. For example, I'd like
references only to appear conflicted if they point to diffent URIs,
irregardless of the content of that Resolved references point to (or
even if the reference is still a Proxy). I believe the current
behavior shows a conflict when the referenced objects aren't "equal".
So, my question would be, what is the best approach to customizing the
DiffEngine behavior in this way? (create a new DiffExtension, extend
GenericDiffEngine, put in a enhancement request for new options passed
to GenericDiffEngine, etc).
Matt
Re: [Compare] DiffEngine: Modifying when Conflicting EReferences occur [message #118989 is a reply to message #118975] |
Fri, 18 April 2008 08:28 |
--------------020003050108090005000507
Matt,
I think the best way of defining such a behavior would be to extend
GenericDiffEngine through the extension point
org.eclipse.emf.compare.diff.engine and to override
GenericDiffEngine#checkReferencesUpdates(DiffGroup, Match3Element).
We tried and make the generic diff engine extensible for such needs so
that clients won't need to create a whole new IDiffEngine for trivial
modifications of the generic behavior. Feel free to give us any feedback
you would have about lack of extensibility or functionalities about the
generic engines.
About options that could be passed on to the Differencing engine ...
This could probably be a cool feature but we need to think about how to
implement it if it can be done ;).
Cheers
Laurent Goubet
Obeo
Matt Seashore a
Re: [Compare] DiffEngine: Modifying when Conflicting EReferences occur [message #119065 is a reply to message #118989] |
Fri, 18 April 2008 15:30 |
Member |
Thanks for the quick reply! I'll reply to this thread if I find issues
extending the GenericDiffEngine.
Thanks again,
Matt
laurent Goubet wrote:
> Matt,
> generic engines.
> Cheers
> Laurent Goubet
> Obeo
>> Thanks,
>> Matt
Re: [Compare] DiffEngine: Modifying when Conflicting EReferences occur [message #617833 is a reply to message #118975] |
Matt,
generic engines.
Cheers
Laurent Goubet
Obeo
Matt Seashore a
Re: [Compare] DiffEngine: Modifying when Conflicting EReferences occur [message #617839 is a reply to message #118989] |
Member |
Thanks again,
Matt
> Matt,
> generic engines.
> Cheers
> Laurent Goubet
> Obeo
>> Thanks,
>> Matt
FUDForum. Page generated in 0.01758 seconds
