Home » Modeling » M2T (model-to-text transformation) » [JET]
[JET] [message #890476] Fri, 22 June 2012 11:41 Go to next message
noi poi is currently offline noi poiFriend
hey hi there
I am new to Model to Text transformation and JET. All i know that JET helps in generating code in java, SQL, XML etc using templates. My confusion is If you have to generate code then the metamodel has to be of hte code nature. Means if you have to generate java code you can only do it through java metamodel and not any other metamodel???
Naurin
Re: [JET] [message #890479 is a reply to message #890476] Fri, 22 June 2012 11:47 Go to previous messageGo to next message
If you're just starting with M2T, you might want to research a bit
harder about what M2T language you use.
JET is very well-established but predates modeling.
Acceleo is meta-model driven with OCL expressions complying with the OMG
MOFM2T standard
Xpand is meta-model driven with enhanced Java expressions
Ed Willink
On 22/06/2012 12:41, noi poi wrote:
> hey hi there
> Naurin
Re: [JET] [message #890858 is a reply to message #890479] Sat, 23 June 2012 08:43 Go to previous messageGo to next message
Thank you Edward for your reply but you see i wanted to know that using any M2T language you can only generate specific code using that specific metamodel.
Java code can only be generated if models are specified in Java metamodel??
Naurin
Re: [JET] [message #890884 is a reply to message #890858] Sat, 23 June 2012 10:15 Go to previous messageGo to next message
You do not seem to understand the abstractions.
M2T uses your (or a library template) to generate text, which just might
happen to be Java or SQL source code. Whether the text actually conforms
to a language specification is entirely down to the diligence of the
template author.
M2M uses your (or a library transformation) to generate 'a' model, which
inherently complies with 'the' target meta-model. If you want inherently
accurate Java then you need to look for a M2M transformation to the Java
meta-model.
Ed Willink
> specific metamodel.
> metamodel??
> Naurin
Re: [JET] [message #891835 is a reply to message #890884] Tue, 26 June 2012 08:50 Go to previous messageGo to next message
Thank you Edward for the explaination. So for the correct code generation, you should follow
1. Source metamodel to Java metamodel transformation
2. Java metamodel to Text code generation.
Naurin
Re: [JET] [message #891864 is a reply to message #891835] Tue, 26 June 2012 11:19 Go to previous message
If you're a model purist. Yes. M2M then trivial M2T.
However for a simple transformation, direct to Java saves a step and has
very rapid debugging feedback so it is more 'fun'.
Ed Willink
> Naurin
Previous Topic:[Acceleo] Extending template with dynamic overriding and class inheritance
Next Topic:[Acceleo] Metamodel resolving and URI
Current Time: Sun Nov 29 04:58:05 GMT 2020
Powered by FUDForum. Page generated in 0.02070 seconds
