Home » Modeling » Epsilon » Strange Model Artifacts(Objects unintentionally created and stored somewhere in my model)
Strange Model Artifacts [message #890158] Thu, 21 June 2012 10:10 Go to next message
Lukas Baron is currently offline Lukas BaronFriend
Hi there,
I discovered maybe a strange bug:
This Code:...
operation utileti!ModelDescriptionRepository createDescription(id,type,path,filename) : utileti!ModelDescription
	var util = new Native("de.baron.plugin.EOLUtil");
	id=id.asString();
	type=type.asString();
	path=path.asString();
	filename=filename.asString();
	var newDescription : utileti!ModelDescription =  self.checkRepository(id,type);
	if (newDescription.isDefined()) return newDescription;
	newDescription = new utileti!ModelDescription;
	newDescription.xmiId = id;
	newDescription.type = type.toMariaModelType();
	newDescription.path = path;
	newDescription.name = filename;
	newDescription.date = util.getCurrentDateTime();
	self.modelDescriptions.add(newDescription);
	("created new modeldescription: '"+filename+"'").println();
... changes this Model:...
  <utileti:UTILETI xmi:id="_GJyToLq_EeGaffhEG04fxw">
    <synchronisationModelRepository xmi:id="_Hgp_8Lq_EeGaffhEG04fxw"/>
    <modelDescriptionRepository xmi:id="_IAYo4Lq_EeGaffhEG04fxw">
    </modelDescriptionRepository>
  </utileti:UTILETI>
</xmi:XMI>
...into this one:
      <modelDescriptions xmi:id="_LjXWcLt6EeG0NJdSKkYuCQ" path="C:/Users/Lukas/Programming/Eclipse-Workspace/SA/de.baron/model/aui.model" name="aui.model" xmiId="_9oArcHgFEeGEQaFIIY_fFA" date="21.06.2012-10:22:03"/>
      <modelDescriptions xmi:id="_Lji8oLt6EeG0NJdSKkYuCQ" path="C:/Users/Lukas/Programming/Eclipse-Workspace/SA/de.baron/model/cui.model" type="cuiDesktop" name="cui.model" xmiId="_ph2vsLpXEeGrA7-mH7AzEg" date="21.06.2012-10:22:03"/>
  </utileti:UTILETI>
  <utileti:ModelDescription xmi:id="_qN7bwbt5EeG0NJdSKkYuCQ" path="C:/Users/Lukas/Programming/Eclipse-Workspace/SA/de.baron/model/aui.model" name="aui.model" xmiId="_9oArcHgFEeGEQaFIIY_fFA"/>
  <utileti:ModelDescription xmi:id="__PkCgLt5EeG0NJdSKkYuCQ" path="C:/Users/Lukas/Programming/Eclipse-Workspace/SA/de.baron/model/aui.model" name="aui.model" xmiId="_9oArcHgFEeGEQaFIIY_fFA"/>
</xmi:XMI>
Note: utileti is an acronym and therefore not incorectly spelled. Razz
One can see two tags "modelDescriptions" as children of "modelDescriptionRepository" appear as it is intended. The same Method createDescription has been executed twice.
Where are these strange Objects "ModelDescription" as children of the root-element from?, which have by the way totally different xmi:id s.
Thanks in Advance
Lukas
[Updated on: Thu, 21 June 2012 10:11]
Report message to a moderator
Re: Strange Model Artifacts [message #890245 is a reply to message #890158] Thu, 21 June 2012 15:15 Go to previous message
Ah ok, I got it. This just happens when errors occur after creating a new object. Running the Programm without errors will lead to a valid model.
No Bug here Rolling Eyes
Previous Topic:Checking a single element using EVL
Next Topic:EGL/EOL java code
Current Time: Thu Apr 25 20:16:59 GMT 2024
Powered by FUDForum. Page generated in 0.03180 seconds
