Home » Modeling » GMF (Graphical Modeling Framework) » how to change the property by only name?
Re: how to change the property by only name? [message #891590 is a reply to message #891585] |
Mon, 25 June 2012 10:05 |
Iqbal Hossain Messages: 101 Registered: May 2011 Location: Bangladesh |
i try to change but having some error....I am not so good in coding
i just want to omit the node type...as u can see in previous post...real Node is type and "aaa" is name...i just need to show aaa.
take a look at the code, if possible help me...
* <copyright>
* </copyright>
* $Id$
package NetworkDiagram.provider;
import NetworkDiagram.Link;
import NetworkDiagram.NetworkDiagramPackage;
import java.util.Collection;
import java.util.List;
import org.eclipse.emf.common.notify.AdapterFactory;
import org.eclipse.emf.common.notify.Notification;
import org.eclipse.emf.common.util.ResourceLocator;
import org.eclipse.emf.edit.provider.ComposeableAdapterFactory;
import org.eclipse.emf.edit.provider.IEditingDomainItemProvider;
import org.eclipse.emf.edit.provider.IItemLabelProvider;
import org.eclipse.emf.edit.provider.IItemPropertyDescriptor;
import org.eclipse.emf.edit.provider.IItemPropertySource;
import org.eclipse.emf.edit.provider.IStructuredItemContentProvider;
import org.eclipse.emf.edit.provider.ITreeItemContentProvider;
import org.eclipse.emf.edit.provider.ItemPropertyDescriptor;
import org.eclipse.emf.edit.provider.ItemProviderAdapter;
import org.eclipse.emf.edit.provider.ViewerNotification;
* This is the item provider adapter for a {@link NetworkDiagram.Link} object.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public class LinkItemProvider
extends ItemProviderAdapter
implements
IEditingDomainItemProvider,
IStructuredItemContentProvider,
ITreeItemContentProvider,
IItemLabelProvider,
IItemPropertySource {
* This constructs an instance from a factory and a notifier.
* @generated
public LinkItemProvider(AdapterFactory adapterFactory) {
super(adapterFactory);
* This returns the property descriptors for the adapted class.
* @generated
public List<IItemPropertyDescriptor> getPropertyDescriptors(Object object) {
if (itemPropertyDescriptors == null) {
super.getPropertyDescriptors(object);
addNamePropertyDescriptor(object);
addBandWidthPropertyDescriptor(object);
addPropagationDelayPropertyDescriptor(object);
addSourcePropertyDescriptor(object);
addTargetPropertyDescriptor(object);
return itemPropertyDescriptors;
* This adds a property descriptor for the Name feature.
* @generated
protected void addNamePropertyDescriptor(Object object) {
itemPropertyDescriptors.add
(createItemPropertyDescriptor
(((ComposeableAdapterFactory)adapterFactory).getRootAdapterFactory(),
getResourceLocator(),
getString("_UI_Link_name_feature"),
getString("_UI_PropertyDescriptor_description", "_UI_Link_name_feature", "_UI_Link_type"),
NetworkDiagramPackage.Literals.LINK__NAME,
true,
false,
false,
ItemPropertyDescriptor.GENERIC_VALUE_IMAGE,
null,
null));
* This adds a property descriptor for the Band Width feature.
* @generated
protected void addBandWidthPropertyDescriptor(Object object) {
getString("_UI_Link_BandWidth_feature"),
getString("_UI_PropertyDescriptor_description", "_UI_Link_BandWidth_feature", "_UI_Link_type"),
NetworkDiagramPackage.Literals.LINK__BAND_WIDTH,
true,
false,
false,
null,
null));
* This adds a property descriptor for the Propagation Delay feature.
* @generated
protected void addPropagationDelayPropertyDescriptor(Object object) {
getString("_UI_Link_PropagationDelay_feature"),
getString("_UI_PropertyDescriptor_description", "_UI_Link_PropagationDelay_feature", "_UI_Link_type"),
NetworkDiagramPackage.Literals.LINK__PROPAGATION_DELAY,
true,
false,
false,
null,
null));
* This adds a property descriptor for the Source feature.
* @generated
protected void addSourcePropertyDescriptor(Object object) {
getString("_UI_Link_source_feature"),
getString("_UI_PropertyDescriptor_description", "_UI_Link_source_feature", "_UI_Link_type"),
NetworkDiagramPackage.Literals.LINK__SOURCE,
true,
false,
true,
null,
null,
null));
* This adds a property descriptor for the Target feature.
* @generated
protected void addTargetPropertyDescriptor(Object object) {
getString("_UI_Link_target_feature"),
getString("_UI_PropertyDescriptor_description", "_UI_Link_target_feature", "_UI_Link_type"),
NetworkDiagramPackage.Literals.LINK__TARGET,
true,
false,
true,
null,
null,
null));
* This returns Link.gif.
* @generated
public Object getImage(Object object) {
return overlayImage(object, getResourceLocator().getImage("full/obj16/Link"));
* This returns the label text for the adapted class.
* @generated
public String getText(Object object) {
String label = ((Link)object).getName();
return label == null || label.length() == 0 ?
getString("_UI_Link_type") :
getString("_UI_Link_type") + " " + label;
* This handles model notifications by calling {@link #updateChildren} to update any cached
* children and by creating a viewer notification, which it passes to {@link #fireNotifyChanged}.
* @generated
public void notifyChanged(Notification notification) {
updateChildren(notification);
switch (notification.getFeatureID(Link.class)) {
case NetworkDiagramPackage.LINK__NAME:
case NetworkDiagramPackage.LINK__BAND_WIDTH:
case NetworkDiagramPackage.LINK__PROPAGATION_DELAY:
fireNotifyChanged(new ViewerNotification(notification, notification.getNotifier(), false, true));
return;
super.notifyChanged(notification);
* This adds {@link org.eclipse.emf.edit.command.CommandParameter}s describing the children
* that can be created under this object.
* @generated
protected void collectNewChildDescriptors(Collection<Object> newChildDescriptors, Object object) {
super.collectNewChildDescriptors(newChildDescriptors, object);
* Return the resource locator for this item provider's resources.
* @generated
public ResourceLocator getResourceLocator() {
return NetworkDiagramEditPlugin.INSTANCE;
Current Time: Tue Apr 23 06:21:19 GMT 2024
Powered by FUDForum. Page generated in 0.05606 seconds
