Re: Problem with WordML preview (version 0.4.0) [message #11251 is a reply to message #11215] |
Wed, 28 January 2009 20:17 |
Ari Nissinen Messages: 12 Registered: July 2009 |
Junior Member |
Hi!
Thanks for answering my questions. Here are the answers:
> Just to clarify the issue, is it the case that a newly imported
> requirement artifact does not have any content? Furthermore, if you try to
> edit the requirement are your changes being saved?
I can import word documents and split them into artifacts. I can now also
see the preview in the eclipse window. If I edit the artifact, the word
document looks empty (no xml tags, even with ctrl+shift+x). If I write
something in it and save it, then this text will replace the earlier
requirement text. Thus, I cannot see the text in Word file, but I can
produce new one and overwrite it ot the OSEE.
> A couple of things to look into:
> 1) When you have the artifact opened for edit can you see mark-up tags
> around the content? (ctrl+shift+x should toggle their visibility)
No, there does not seem to be those. When I edit the word template in
Common branch, then I can see the xml-tags in the word file.
> 2) After you have changed the text and saved the document do you see a new
> entry in the resource history view? (Right click on the artifact in the
> artifact explorer and select show resource history). Every time you make a
> change to the artifact a new entry should occur with corresponding time
> and date.
Yes, I do, it says that the word content has changed.
> 3) What is the type of the artifact? From the Artifact Explorer if you
> select the triangle menu selection in the right hand corner you will see a
> menu item Show Artifact Type.
I have tried "system requirement" and "software requirement" among others,
that can have word content.
To me it looks like that OSEE side is ok now, as it can send out files and
take the input back. Maybe the problem is at Word side. Do I need to have
some xslt or schema installed for parsing the XML file the OSEE is
sending. Sorry for my incompetence in XML...
Ari
PS: If I get OSEE and Word working together, my next worry will be
creating templates for reporting the content of OSEE. I am seriously
studying the system for applying it for my work. All help would be greatly
appreciated!
Re: Problem with WordML preview (version 0.4.0) [message #571981 is a reply to message #11215] |
Junior Member |
Hi!
> and date.
Ari
appreciated!
FUDForum. Page generated in 0.04450 seconds
