Home » Eclipse Projects » Remote Application Platform (RAP) » Working with internal browser(Issue when using internal browser)
Working with internal browser [message #888739] |
Mon, 18 June 2012 15:11 |
Waldemar Cichon Messages: 3 Registered: June 2012 |
Hi to all,
befor 1.4 M5 the internal browser in the Eclipse IDE worked very fine. After some milestone the browser crashed on start with a scripting error. I thought, that is a zooming related problem, which was fixed in 1.5. But after installing the new version the bug remaines. I get every time I try to start my app the following error. On external browsers, IE, Chrome and FF tested, there where no problems with this.
Could not process server response:
Error: Error: Could not copy fill: VML._copyData: source or target missing.
Script: {
"meta": {
"requestCounter": 0
"operations": [ [ "set", "w1", {
"currentTheme": "org.eclipse.swt.theme.Custom_e0cb5197"
} ], [ "create", "w2", "rwt.widgets.Shell", {
"style": [ "CLOSE", "MIN", "MAX", "RESIZE", "TITLE" ],
"minimumSize": [ 80, 26 ],
"bounds": [ 0, 0, 740, 374 ],
"children": [],
"tabIndex": -1
} ], [ "create", "w3", "rwt.widgets.Shell", {
"style": [ "TITLE" ],
"parentShell": "w2",
"text": "Login",
"active": true,
"defaultButton": "w9",
"activeControl": "w14",
"bounds": [ 407, 187, 420, 250 ],
"children": [ "w4" ],
"tabIndex": -1,
"visibility": true
} ], [ "listen", "w3", {
"shell": true
} ], [ "create", "w4", "rwt.widgets.Composite", {
"parent": "w3",
"style": [ "NONE" ],
"bounds": [ 5, 27, 406, 214 ],
"children": [ "w43", "w51" ],
"tabIndex": -1
} ], [ "create", "w43", "rwt.widgets.Composite", {
"parent": "w4",
"bounds": [ 0, 0, 406, 167 ],
"children": [ "w42" ],
"tabIndex": -1
} ], [ "create", "w42", "rwt.widgets.Composite", {
"parent": "w43",
"bounds": [ 9, 10, 428, 293 ],
"children": [ "w12", "w17", "w8" ],
"tabIndex": -1
} ], [ "create", "w12", "rwt.widgets.Composite", {
"parent": "w42",
"bounds": [ 0, 0, 428, 61 ],
"children": [ "w5", "w11", "w6", "w7" ],
"tabIndex": -1,
"background": [ 255, 255, 255, 255 ]
} ], [ "create", "w5", "rwt.widgets.Label", {
"parent": "w12",
"appearance": "clabel",
"bounds": [ 0, 0, 317, 23 ],
"children": [],
"tabIndex": -1,
"background": [ 0, 0, 0, 0 ],
"customVariant": "variant_title",
"text": "Welcome to Flight Data Capture"
} ], [ "create", "w11", "rwt.widgets.Label", {
"parent": "w12",
"bounds": [ 322, 10, 106, 25 ],
"tabIndex": -1,
"image": [ "rwt-resources/generated/8a035f8d", 106, 25 ]
} ], [ "create", "w6", "rwt.widgets.Label", {
"parent": "w12",
"bounds": [ 0, 23, 317, 23 ],
"children": [],
"tabIndex": -1,
"text": "[ Production ]"
} ], [ "create", "w7", "rwt.widgets.Label", {
"parent": "w12",
"bounds": [ 0, 46, 317, 15 ],
"children": [],
"tabIndex": -1,
"foreground": [ 255, 0, 0, 255 ],
"customVariant": "variant_error"
} ], [ "create", "w17", "rwt.widgets.Composite", {
"parent": "w42",
"bounds": [ 0, 66, 428, 57 ],
"children": [ "w13", "w14", "w15", "w16" ],
"tabIndex": -1
} ], [ "create", "w13", "rwt.widgets.Label", {
"parent": "w17",
"bounds": [ 0, 1, 48, 16 ],
"tabIndex": -1,
"text": "Username:"
} ], [ "create", "w14", "rwt.widgets.Text", {
"parent": "w17",
"style": [ "LEFT", "SINGLE", "BORDER" ],
"bounds": [ 53, 0, 375, 19 ],
"tabIndex": 9
} ], [ "listen", "w14", {
"focus": true
} ], [ "set", "w14", {
"customVariant": "variant_comp"
"modify": true
} ], [ "create", "w15", "rwt.widgets.Label", {
"parent": "w17",
"bounds": [ 0, 25, 48, 16 ],
"tabIndex": -1,
"text": "Password:"
} ], [ "create", "w16", "rwt.widgets.Text", {
"parent": "w17",
"style": [ "LEFT", "SINGLE", "PASSWORD", "BORDER" ],
"bounds": [ 53, 24, 375, 19 ],
"tabIndex": 10,
"customVariant": "variant_comp",
"echoChar": "?"
} ], [ "listen", "w16", {
"modify": true
} ], [ "create", "w8", "rwt.widgets.Composite", {
"parent": "w42",
"bounds": [ 0, 128, 428, 165 ],
"children": [ "w18", "w21", "w27", "w30", "w38", "w41" ],
"tabIndex": -1
} ], [ "create", "w18", "rwt.widgets.Composite", {
"parent": "w8",
"bounds": [ 0, 0, 428, 165 ],
"children": [],
"tabIndex": -1
} ], [ "create", "w21", "rwt.widgets.Composite", {
"parent": "w8",
"children": [ "w20" ],
"tabIndex": -1,
"visibility": false
} ], [ "create", "w20", "rwt.widgets.Composite", {
"parent": "w21",
"style": [ "BORDER" ],
"bounds": [ 0, 5, 428, 19 ],
"children": [ "w19" ],
"tabIndex": -1,
"background": [ 240, 210, 210, 255 ]
} ], [ "create", "w19", "rwt.widgets.Label", {
"parent": "w20",
"style": [ "WRAP" ],
"bounds": [ 3, 3, 0, 11 ],
"tabIndex": -1,
"visibility": false,
} ], [ "create", "w27", "rwt.widgets.Composite", {
"parent": "w8",
"children": [ "w26" ],
"tabIndex": -1,
"visibility": false
} ], [ "create", "w26", "rwt.widgets.Composite", {
"parent": "w27",
"bounds": [ 0, 5, 428, 93 ],
"children": [ "w22", "w23", "w24", "w25" ],
"tabIndex": -1,
"background": [ 242, 245, 255, 255 ]
} ], [ "create", "w22", "rwt.widgets.Label", {
"parent": "w26",
"bounds": [ 5, 5, 416, 57 ],
"tabIndex": -1,
"background": [ 242, 245, 255, 255 ],
"text": "Forgot Password:\n\nEnter your user name or the corresponding email address into the field below and press \"Send\" to get a new password."
} ], [ "create", "w23", "rwt.widgets.Label", {
"parent": "w26",
"bounds": [ 5, 68, 143, 16 ],
"tabIndex": -1,
"text": "User name or mail address: "
} ], [ "create", "w24", "rwt.widgets.Text", {
"parent": "w26",
"bounds": [ 153, 67, 230, 19 ],
"tabIndex": 17
} ], [ "create", "w25", "rwt.widgets.Button", {
"parent": "w26",
"style": [ "PUSH" ],
"bounds": [ 388, 67, 33, 19 ],
"tabIndex": 18,
"font": [ [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false ],
"text": "Send"
} ], [ "listen", "w25", {
"selection": true
} ], [ "create", "w30", "rwt.widgets.Composite", {
"parent": "w8",
"children": [ "w29" ],
"tabIndex": -1,
"visibility": false
} ], [ "create", "w29", "rwt.widgets.Composite", {
"parent": "w30",
"bounds": [ 0, 5, 428, 65 ],
"children": [ "w28" ],
"tabIndex": -1,
} ], [ "create", "w28", "rwt.widgets.Label", {
"parent": "w29",
"bounds": [ 3, 3, 359, 57 ],
"tabIndex": -1,
"text": "The email with a temporary password has been sent to your email \naddress. \nPlease check your mail account and login with the password provided \nin the email."
} ], [ "create", "w38", "rwt.widgets.Composite", {
"parent": "w8",
"children": [ "w37" ],
"tabIndex": -1,
"visibility": false
} ], [ "create", "w37", "rwt.widgets.Composite", {
"parent": "w38",
"bounds": [ 0, 5, 428, 155 ],
"children": [ "w31", "w32", "w33", "w34", "w35", "w36" ],
"tabIndex": -1,
} ], [ "create", "w31", "rwt.widgets.Label", {
"parent": "w37",
"bounds": [ 5, 5, 416, 71 ],
"tabIndex": -1,
"text": "You have successfully logged in with a temporary password, thus you have to set a new one. To change your password, enter the new password in the fields below. \nYour password should be easy for you to remember, but hard for others to guess. If your password can be guessed, then your account is not secure."
} ], [ "create", "w32", "rwt.widgets.Label", {
"parent": "w37",
"bounds": [ 5, 82, 63, 16 ],
"tabIndex": -1,
"text": "New password"
} ], [ "create", "w33", "rwt.widgets.Text", {
"parent": "w37",
"bounds": [ 89, 81, 332, 19 ],
"tabIndex": 23,
"echoChar": "?"
} ], [ "create", "w34", "rwt.widgets.Label", {
"parent": "w37",
"bounds": [ 5, 106, 79, 16 ],
"tabIndex": -1,
"text": "Repeat password"
} ], [ "create", "w35", "rwt.widgets.Text", {
"parent": "w37",
"bounds": [ 89, 105, 332, 19 ],
"tabIndex": 24,
"echoChar": "?"
} ], [ "create", "w36", "rwt.widgets.Button", {
"parent": "w37",
"bounds": [ 330, 129, 91, 19 ],
"tabIndex": 25,
"text": "Change password"
} ], [ "listen", "w36", {
"selection": true
} ], [ "create", "w41", "rwt.widgets.Composite", {
"parent": "w8",
"children": [ "w40" ],
"tabIndex": -1,
"visibility": false
} ], [ "create", "w40", "rwt.widgets.Composite", {
"parent": "w41",
"bounds": [ 0, 5, 428, 38 ],
"children": [ "w39" ],
"tabIndex": -1,
} ], [ "create", "w39", "rwt.widgets.Label", {
"parent": "w40",
"bounds": [ 3, 3, 216, 30 ],
"tabIndex": -1,
"text": "Password successfully changed.\nPlease wait for the application to start."
} ], [ "create", "w51", "rwt.widgets.Composite", {
"parent": "w4",
"bounds": [ 4, 167, 402, 47 ],
"children": [ "w50" ],
"tabIndex": -1,
} ], [ "create", "w50", "rwt.widgets.Composite", {
"parent": "w51",
"bounds": [ 5, 0, 392, 47 ],
"children": [ "w44", "w45", "w46", "w47", "w48", "w49" ],
"tabIndex": -1
} ], [ "create", "w44", "rwt.widgets.Label", {
"parent": "w50",
"bounds": [ 5, 3, 0, 11 ],
"tabIndex": -1,
"visibility": false
} ], [ "create", "w45", "rwt.widgets.Label", {
"parent": "w50",
"bounds": [ 134, 3, 0, 11 ],
"tabIndex": -1,
"visibility": false
} ], [ "create", "w46", "rwt.widgets.Link", {
"parent": "w50",
"bounds": [ 304, 0, 83, 18 ],
"tabIndex": 30,
"foreground": [ 0, 0, 255, 255 ]
} ], [ "listen", "w46", {
"mouse": true
} ], [ "set", "w46", {
"text": [ [ "Forgot password", 0 ] ]
} ], [ "create", "w47", "rwt.widgets.Label", {
"parent": "w50",
"bounds": [ 5, 24, 42, 16 ],
"tabIndex": -1,
"text": "v 5.15.0"
} ], [ "create", "w48", "rwt.widgets.Label", {
"parent": "w50",
"bounds": [ 134, 36, 124, 11 ],
"tabIndex": -1
} ], [ "create", "w49", "rwt.widgets.Composite", {
"parent": "w50",
"bounds": [ 301, 18, 86, 29 ],
"children": [ "w9", "w10" ],
"tabIndex": -1
} ], [ "create", "w9", "rwt.widgets.Button", {
"parent": "w49",
"bounds": [ 0, 5, 38, 19 ],
"tabIndex": 331,
"text": "Login"
} ], [ "listen", "w9", {
"selection": true
} ], [ "create", "w10", "rwt.widgets.Button", {
"parent": "w49",
"bounds": [ 48, 5, 38, 19 ],
"tabIndex": 332,
"text": "Reset"
} ], [ "listen", "w10", {
"selection": true
} ], [ "set", "w1", {
"focusControl": "w14"
} ], [ "call", "w1", "probe", {
"fonts": [ [ -754656601, "!#$%&()*+,-./0123456789:;<=>?@AzByCxDwEvFuGtHsIrJqKpLoMnNmOlPkQjRiShTgUfVeWdXcYbZa[\\]^_`", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false ], [ -754655578, "!#$%&()*+,-./0123456789:;<=>?@AzByCxDwEvFuGtHsIrJqKpLoMnNmOlPkQjRiShTgUfVeWdXcYbZa[\\]^_`", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 15, true, false ] ]
} ], [ "call", "w1", "measureStrings", {
"strings": [ [ -34484987, "v 5.15.0", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, -1, false ], [ -108054428, "Login", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, -1, false ], [ -1994140996, "Repeat password", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, -1, false ], [ 1149222278, "Change password", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, -1, false ], [ 646677706, "Reset", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, -1, false ], [ 956556411, "Password:", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, -1, false ], [ 1961831622, "Forgot Password:\n\nEnter your user name or the corresponding email address into the field below and press \"Send\" to get a new password.", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, 350, false ], [ -691787680, "Username:", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, -1, false ], [ -31039294, "You have successfully logged in with a temporary password, thus you have to set a new one. To change your password, enter the new password in the fields below. \nYour password should be easy for you to remember, but hard for others to guess. If your password can be guessed, then your account is not secure.", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, 350, false ], [ -1122912584, "[ Production ]", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 15, true, false, -1, false ], [ -1077744598, "User name or mail address: ", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, -1, false ], [ -951429686, "The email with a temporary password has been sent to your email \naddress. \nPlease check your mail account and login with the password provided \nin the email.", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, -1, false ], [ 1961833668, "Forgot Password:\n\nEnter your user name or the corresponding email address into the field below and press \"Send\" to get a new password.", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, 416, false ], [ 357818627, "Send", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, -1, false ], [ -362570281, "New password", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, -1, false ], [ -1390870746, "Password successfully changed.\nPlease wait for the application to start.", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, -1, false ], [ 1262245014, "Welcome to Flight Data Capture", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 15, true, false, -1, false ], [ -31037248, "You have successfully logged in with a temporary password, thus you have to set a new one. To change your password, enter the new password in the fields below. \nYour password should be easy for you to remember, but hard for others to guess. If your password can be guessed, then your account is not secure.", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, 416, false ], [ 326948916, "Forgot password", [ "Arial", "Verdana", "Lucida Sans", "Helvetica", "sans-serif" ], 11, false, false, -1, false ] ]
description: Could not copy fill: VML._copyData: source or target missing.
message: Could not copy fill: VML._copyData: source or target missing.
Debug: on
Request: rwt_initialize=true&w1.bounds.width=1234&w1.bounds.height=624&w1.dpi.x=96&w1.dpi.y=96&w1.colorDepth=24&w1.cursorLocation.x=0&w1.cursorLocation.y=0&uiRoot=w1
Phase: 6
Re: Working with internal browser [message #889538 is a reply to message #888739] |
Tue, 19 June 2012 10:28 |
Tim Buschtoens Messages: 396 Registered: July 2009 |
Hi.
Which RAP version are you on now exactly? Something like this was fixed
in M6. There might also be changes related to this later on, did you try
RC3?
Also, what windows version are you using exactly? 32bit or 64 bit? And
what IE version do you have installed?
Greetings,
Tim
Am 18.06.2012 17:11, schrieb Waldemar Cichon:
> Hi to all,
> Script: {
> "meta": {
> "requestCounter": 0
> "children": [],
> "tabIndex": -1
> "text": "Login",
> "active": true,
> "tabIndex": -1,
> "visibility": true
> "shell": true
> "parent": "w3",
> "tabIndex": -1
> "parent": "w4",
> "tabIndex": -1
> "parent": "w43",
> "tabIndex": -1
> "parent": "w42",
> "tabIndex": -1,
> "parent": "w12",
> "children": [],
> "tabIndex": -1,
> "parent": "w12",
> "tabIndex": -1,
> "parent": "w12",
> "children": [],
> "tabIndex": -1,
> "parent": "w12",
> "children": [],
> "tabIndex": -1,
> "parent": "w42",
> "tabIndex": -1
> "parent": "w17",
> "tabIndex": -1,
> "text": "Username:"
> "parent": "w17",
> "tabIndex": 9
> "focus": true
> "modify": true
> "parent": "w17",
> "tabIndex": -1,
> "text": "Password:"
> "parent": "w17",
> "tabIndex": 10,
> "echoChar": "?"
> "modify": true
> "parent": "w42",
> "tabIndex": -1
> "parent": "w8",
> "children": [],
> "tabIndex": -1
> "parent": "w8",
> "tabIndex": -1,
> "visibility": false
> "parent": "w21",
> "tabIndex": -1,
> "parent": "w20",
> "tabIndex": -1,
> "parent": "w8",
> "tabIndex": -1,
> "visibility": false
> "parent": "w27",
> "tabIndex": -1,
> "parent": "w26",
> "tabIndex": -1,
> password."
> "parent": "w26",
> "tabIndex": -1,
> "parent": "w26",
> "tabIndex": 17
> "parent": "w26",
> "tabIndex": 18,
> "text": "Send"
> "selection": true
> "parent": "w8",
> "tabIndex": -1,
> "visibility": false
> "parent": "w30",
> "tabIndex": -1,
> "parent": "w29",
> "tabIndex": -1,
> "parent": "w8",
> "tabIndex": -1,
> "visibility": false
> "parent": "w38",
> "tabIndex": -1,
> "parent": "w37",
> "tabIndex": -1,
> "parent": "w37",
> "tabIndex": -1,
> "parent": "w37",
> "tabIndex": 23,
> "echoChar": "?"
> "parent": "w37",
> "tabIndex": -1,
> "parent": "w37",
> "tabIndex": 24,
> "echoChar": "?"
> "parent": "w37",
> "tabIndex": 25,
> "selection": true
> "parent": "w8",
> "tabIndex": -1,
> "visibility": false
> "parent": "w41",
> "tabIndex": -1,
> "parent": "w40",
> "tabIndex": -1,
> to start."
> "parent": "w4",
> "tabIndex": -1,
> "parent": "w51",
> "tabIndex": -1
> "parent": "w50",
> "tabIndex": -1,
> "visibility": false
> "parent": "w50",
> "tabIndex": -1,
> "visibility": false
> "parent": "w50",
> "tabIndex": 30,
> "mouse": true
> "parent": "w50",
> "tabIndex": -1,
> "text": "v 5.15.0"
> "parent": "w50",
> "tabIndex": -1
> "parent": "w50",
> "tabIndex": -1
> "parent": "w49",
> "tabIndex": 331,
> "text": "Login"
> "selection": true
> "parent": "w49",
> "tabIndex": 332,
> "text": "Reset"
> "selection": true
> true, false ] ]
> Debug: on
> Request:
> Phase: 6
Tim Buschtöns
Twitter: @EclipseRAP
Re: Working with internal browser [message #892187 is a reply to message #889538] |
Wed, 27 June 2012 10:56 |
Hi Tim,
thank you for the reply and sorry for my delay.
These tests where done with RAP 1.5 RC3.
I'm using a 64bit Windows 7 machine, and the IE is the current IE(9), with all newest patches installed. There's no other IE on the computer, but i also have installed the current FF and Chrome on it.
Waldemar
[Updated on: Wed, 27 June 2012 11:00] Report message to a moderator
Current Time: Thu Mar 28 18:33:57 GMT 2024
Powered by FUDForum. Page generated in 0.02283 seconds
