Home » Language IDEs » ServerTools (WTP) » Database browsing issue
Database browsing issue [message #117977] Fri, 08 July 2005 08:54 Go to next message
Originally posted by: susanne.deiters.gmail.com
Hi all,
I'm using WTP 1.0 M5 with Eclipse 3.1.
I've successfully established a connection to an Oracle database using
Server Explorer and the schemas of the db are shown. But I have two
problems:
1. No columns are shown for the tables
2. In a former WTP version there was the option data -> browse when
rightclicking a table, which resulted in table data being shown in view
Data Output (former DB Output). There's no browse option anymore and I'm
not able to get the data into view Data Output.
Any ideas?
Thanks in advance,
Susanne
Re: Database browsing issue [message #117991 is a reply to message #117977] Fri, 08 July 2005 09:11 Go to previous messageGo to next message
Originally posted by: cooll.free.fr
Susanne Deiters wrote:
> Hi all,
Same problem for me.
Here is the exception I get when trying to display the columns of a table:
org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBounds Exception:
index=0, size=0
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:5 11)
at
org.eclipse.wst.rdb.data.internal.ui.editor.CursorAction.isC olumnNullable(Ta
bleDataEditorActionBarContributor.java:209)
at
org.eclipse.wst.rdb.data.internal.ui.editor.TableDataEditorA ctionBarContribu
tor$4.isEnabled(TableDataEditorActionBarContributor.java:57)
at
org.eclipse.jface.action.ActionContributionItem.update(Actio nContributionIte
m.java:815)
at
org.eclipse.jface.action.ActionContributionItem.fill(ActionC ontributionItem.
java:281)
at
org.eclipse.jface.action.SubContributionItem.fill(SubContrib utionItem.java:6
5)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :627)
at org.eclipse.jface.action.MenuManager.updateAll(MenuManager.j ava:721)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :646)
at
org.eclipse.ui.internal.WorkbenchWindow.updateActionBars(Wor kbenchWindow.jav
a:2485)
followed by:
Unhandled event loop exception
and:
java.lang.ArrayIndexOutOfBoundsException: 0
at
org.eclipse.jface.viewers.TableEditorImpl.activateCellEditor (TableEditorImpl
..java:70)
at
..java:145)
at
org.eclipse.jface.viewers.TableEditorImpl.handleMouseDown(Ta bleEditorImpl.ja
va:271)
at org.eclipse.jface.viewers.TableViewer$2.mouseDown(TableViewe r.java:608)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:133)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
Re: Database browsing issue [message #118056 is a reply to message #117991] Fri, 08 July 2005 09:47 Go to previous message
>>Hi all,
> index=0, size=0
> at
> at
> at
> m.java:815)
> at
> java:281)
> at
> 5)
> at
> a:2485)
> followed by:
> and:
> at
> .java:70)
> at
> .java:145)
> at
> va:271)
Thanks for your response, I didn't look into the log file so far. I get
this exception too.
Previous Topic:The server may already be running in another process, or a system process may be using the port.
Next Topic:slow wsdl editor
Current Time: Sun May 18 10:39:32 EDT 2025
Powered by FUDForum. Page generated in 0.03121 seconds
